Odm aukerman demo constantly crashes on workstation with 128GB RAM and intel i9 9900x
Hi, I really wanted to give this a try, but it constantly crashes the whole computer when processing the aukerman demo set. Default settings and powerful workstation, running on windows 10, wsl2 Ubuntu 20.04, windows version: 2004 build 19041.572 Do you guys have an idea of why is this happening?
I have lost my patience with it
[INFO] Initializing ODM - Wed Nov 11 19:59:55 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 2.0
[INFO] depthmap_resolution: 1000.0
[INFO] dsm: True
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: True
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 18
[INFO] merge: all
[INFO] mesh_octree_depth: 10
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: b51eac24-3305-4792-b4cd-3d74601a47cd
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 2.0
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_multitracks: False
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/b51eac24-3305-4792-b4cd-3d74601a47cd/images
[INFO] Loading 77 images
[INFO] Wrote images database: /var/www/data/b51eac24-3305-4792-b4cd-3d74601a47cd/images.json
[INFO] Found 77 usable images
[INFO] Parsing SRS header: WGS84 UTM 17N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 4896px
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2448’, ‘feature_min_frames: 8000’, ‘processes: 18’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘depthmap_method: PATCH_MATCH’, ‘depthmap_resolution: 1000.0’, ‘depthmap_min_patch_sd: 1’, ‘depthmap_min_consistent_views: 3’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘bundle_common_position_constraints: no’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm extract_metadata “/var/www/data/b51eac24-3305-4792-b4cd-3d74601a47cd/opensfm”
2020-11-11 19:59:56,698 INFO: Extracting EXIF for DSC00287.JPG
2020-11-11 19:59:56,764 INFO: Extracting EXIF for DSC00267.JPG
2020-11-11 19:59:56,821 INFO: Extracting EXIF for DSC00253.JPG
2020-11-11 19:59:56,870 INFO: Extracting EXIF for DSC00271.JPG
2020-11-11 19:59:56,931 INFO: Extracting EXIF for DSC00230.JPG
2020-11-11 19:59:57,000 INFO: Extracting EXIF for DSC00256.JPG
2020-11-11 19:59:57,055 INFO: Extracting EXIF for DSC00254.JPG
2020-11-11 19:59:57,105 INFO: Extracting EXIF for DSC00291.JPG
2020-11-11 19:59:57,155 INFO: Extracting EXIF for DSC00295.JPG
2020-11-11 19:59:57,206 INFO: Extracting EXIF for DSC00310.JPG
2020-11-11 19:59:57,249 INFO: Extracting EXIF for DSC00229.JPG
2020-11-11 19:59:57,310 INFO: Extracting EXIF for DSC00249.JPG
2020-11-11 19:59:57,358 INFO: Extracting EXIF for DSC00240.JPG
2020-11-11 19:59:57,418 INFO: Extracting EXIF for DSC00235.JPG
2020-11-11 19:59:57,475 INFO: Extracting EXIF for DSC00244.JPG
2020-11-11 19:59:57,529 INFO: Extracting EXIF for DSC00298.JPG
2020-11-11 19:59:57,587 INFO: Extracting EXIF for DSC00237.JPG
2020-11-11 19:59:57,642 INFO: Extracting EXIF for DSC00292.JPG
2020-11-11 19:59:57,693 INFO: Extracting EXIF for DSC00293.JPG
2020-11-11 19:59:57,748 INFO: Extracting EXIF for DSC00283.JPG
2020-11-11 19:59:57,809 INFO: Extracting EXIF for DSC00273.JPG
2020-11-11 19:59:57,869 INFO: Extracting EXIF for DSC00290.JPG
2020-11-11 19:59:57,918 INFO: Extracting EXIF for DSC00303.JPG
2020-11-11 19:59:57,968 INFO: Extracting EXIF for DSC00251.JPG
2020-11-11 19:59:58,019 INFO: Extracting EXIF for DSC00307.JPG
2020-11-11 19:59:58,075 INFO: Extracting EXIF for DSC00272.JPG
2020-11-11 19:59:58,136 INFO: Extracting EXIF for DSC00305.JPG
2020-11-11 19:59:58,186 INFO: Extracting EXIF for DSC00308.JPG
2020-11-11 19:59:58,229 INFO: Extracting EXIF for DSC00300.JPG
2020-11-11 19:59:58,286 INFO: Extracting EXIF for DSC00269.JPG
2020-11-11 19:59:58,418 INFO: Extracting EXIF for DSC00258.JPG
2020-11-11 19:59:58,473 INFO: Extracting EXIF for DSC00294.JPG
2020-11-11 19:59:58,523 INFO: Extracting EXIF for DSC00276.JPG
2020-11-11 19:59:58,577 INFO: Extracting EXIF for DSC00259.JPG
2020-11-11 19:59:58,626 INFO: Extracting EXIF for DSC00233.JPG
2020-11-11 19:59:58,688 INFO: Extracting EXIF for DSC00239.JPG
2020-11-11 19:59:58,746 INFO: Extracting EXIF for DSC00288.JPG
2020-11-11 19:59:58,798 INFO: Extracting EXIF for DSC00304.JPG
2020-11-11 19:59:58,848 INFO: Extracting EXIF for DSC00277.JPG
2020-11-11 19:59:58,902 INFO: Extracting EXIF for DSC00309.JPG
2020-11-11 19:59:58,955 INFO: Extracting EXIF for DSC00255.JPG
2020-11-11 19:59:59,006 INFO: Extracting EXIF for DSC00285.JPG
2020-11-11 19:59:59,064 INFO: Extracting EXIF for DSC00234.JPG
2020-11-11 19:59:59,124 INFO: Extracting EXIF for DSC00284.JPG
2020-11-11 19:59:59,177 INFO: Extracting EXIF for DSC00260.JPG
2020-11-11 19:59:59,223 INFO: Extracting EXIF for DSC00241.JPG
2020-11-11 19:59:59,280 INFO: Extracting EXIF for DSC00232.JPG
2020-11-11 19:59:59,339 INFO: Extracting EXIF for DSC00301.JPG
2020-11-11 19:59:59,398 INFO: Extracting EXIF for DSC00302.JPG
2020-11-11 19:59:59,449 INFO: Extracting EXIF for DSC00282.JPG
2020-11-11 19:59:59,502 INFO: Extracting EXIF for DSC00286.JPG
2020-11-11 19:59:59,560 INFO: Extracting EXIF for DSC00268.JPG
2020-11-11 19:59:59,623 INFO: Extracting EXIF for DSC00297.JPG
2020-11-11 19:59:59,676 INFO: Extracting EXIF for DSC00252.JPG
2020-11-11 19:59:59,723 INFO: Extracting EXIF for DSC00299.JPG
2020-11-11 19:59:59,777 INFO: Extracting EXIF for DSC00275.JPG
2020-11-11 19:59:59,827 INFO: Extracting EXIF for DSC00261.JPG
2020-11-11 19:59:59,875 INFO: Extracting EXIF for DSC00265.JPG
2020-11-11 19:59:59,925 INFO: Extracting EXIF for DSC00238.JPG
2020-11-11 19:59:59,980 INFO: Extracting EXIF for DSC00280.JPG
2020-11-11 20:00:00,033 INFO: Extracting EXIF for DSC00296.JPG
2020-11-11 20:00:00,082 INFO: Extracting EXIF for DSC00279.JPG
2020-11-11 20:00:00,131 INFO: Extracting EXIF for DSC00247.JPG
2020-11-11 20:00:00,178 INFO: Extracting EXIF for DSC00270.JPG
2020-11-11 20:00:00,236 INFO: Extracting EXIF for DSC00246.JPG
2020-11-11 20:00:00,290 INFO: Extracting EXIF for DSC00264.JPG
2020-11-11 20:00:00,347 INFO: Extracting EXIF for DSC00257.JPG
2020-11-11 20:00:00,409 INFO: Extracting EXIF for DSC00289.JPG
2020-11-11 20:00:00,461 INFO: Extracting EXIF for DSC00263.JPG
2020-11-11 20:00:00,512 INFO: Extracting EXIF for DSC00311.JPG
2020-11-11 20:00:00,566 INFO: Extracting EXIF for DSC00281.JPG
2020-11-11 20:00:00,624 INFO: Extracting EXIF for DSC00306.JPG
2020-11-11 20:00:00,672 INFO: Extracting EXIF for DSC00278.JPG
2020-11-11 20:00:00,723 INFO: Extracting EXIF for DSC00242.JPG
2020-11-11 20:00:00,786 INFO: Extracting EXIF for DSC00236.JPG
2020-11-11 20:00:00,846 INFO: Extracting EXIF for DSC00274.JPG
[INFO] running /code/SuperBuild/src/opensfm/bin/opensfm detect_features “/var/www/data/b51eac24-3305-4792-b4cd-3d74601a47cd/opensfm”
2020-11-11 20:00:01,577 INFO: ********* Loky back-end testing, please ignore errors below. *********
2020-11-11 20:00:01,786 INFO: ************* Loky back-end test done ************************************
2020-11-11 20:00:01,786 INFO: Using loky as parallel backend.
2020-11-11 20:00:02,551 INFO: Extracting ROOT_SIFT features for image DSC00287.JPG
2020-11-11 20:00:02,557 INFO: Extracting ROOT_SIFT features for image DSC00253.JPG
2020-11-11 20:00:02,561 INFO: Extracting ROOT_SIFT features for image DSC00271.JPG
2020-11-11 20:00:02,561 INFO: Extracting ROOT_SIFT features for image DSC00230.JPG
2020-11-11 20:00:02,564 INFO: Extracting ROOT_SIFT features for image DSC00267.JPG
2020-11-11 20:00:02,572 INFO: Extracting ROOT_SIFT features for image DSC00256.JPG
2020-11-11 20:00:02,574 INFO: Extracting ROOT_SIFT features for image DSC00295.JPG
2020-11-11 20:00:02,576 INFO: Extracting ROOT_SIFT features for image DSC00254.JPG
2020-11-11 20:00:02,579 INFO: Extracting ROOT_SIFT features for image DSC00229.JPG
2020-11-11 20:00:02,592 INFO: Extracting ROOT_SIFT features for image DSC00244.JPG
2020-11-11 20:00:02,594 INFO: Extracting ROOT_SIFT features for image DSC00240.JPG
2020-11-11 20:00:02,601 INFO: Extracting ROOT_SIFT features for image DSC00235.JPG
2020-11-11 20:00:02,604 INFO: Extracting ROOT_SIFT features for image DSC00310.JPG
2020-11-11 20:00:02,606 INFO: Extracting ROOT_SIFT features for image DSC00249.JPG
2020-11-11 20:00:02,620 INFO: Extracting ROOT_SIFT features for image DSC00298.JPG
2020-11-11 20:00:02,620 INFO: Extracting ROOT_SIFT features for image DSC00291.JPG
2020-11-11 20:00:02,631 INFO: Extracting ROOT_SIFT features for image DSC00237.JPG
2020-11-11 20:00:02,671 INFO: Extracting ROOT_SIFT features for image DSC00292.JPG
2020-11-11 20:00:02,947 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:02,960 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:02,965 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:02,972 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:02,985 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:02,988 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:02,993 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,014 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,031 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,060 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,063 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,065 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,075 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,104 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,110 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,138 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,168 DEBUG: Computing sift with threshold 0.1
2020-11-11 20:00:03,178 DEBUG: Computing sift with threshold 0.1
How did you get ODM running under WSL?
First I built directly in Ubuntu, from the github repository OpenDroneMap/ODM.git
Then I purchased the installer for Web ODM, it fails in the exact same way (crashes the whole computer)
I have it working on a laptop, I do not understand why it fails here
Strange; try to rebuild the docker image?
docker build -t opendronemap/odm .
Thanks for your reply. It finally was a bios problem and not a software one.
Could you share some details for future reference (what was the problem with the bios?) I’m really interested in knowing what was wrong, as I’ve never seen that error before, I’m sure others are curious too. :pray:
Would like to know as well !
Probably Virtualization (vt-x or vt-d) not enable
