When I’m running the OpenDroneMap natively in ubuntu 16.04.6 in a vmware virtual machine, I’ll encounter following error at the meshing stage
/bin/sh: 1: /home/ravindu/Documents/OpenDroneMap-v0.4/build/bin/odm_25dmeshing: not found
File “/home/ravindu/Documents/OpenDroneMap-v0.4/run.py”, line 47, in
plasm.execute(niter=1)
File “/home/ravindu/Documents/OpenDroneMap-v0.4/scripts/odm_meshing.py”, line 106, in process
‘-resolution {resolution} {verbose}’.format(**kwargs))
File “/home/ravindu/Documents/OpenDroneMap-v0.4/opendm/system.py”, line 34, in run
Exception: Child returned 127
command I executed to run OpenDroneMap is ./run.sh odm_data_aukerman --project-path /home/ravindu/Documents/ODMProject/ --fast-orthophoto.
Anyone knows the answer ?
Complete log in terminal is given below
[INFO] Fast orthophoto is turned on, automatically setting --use-25dmesh
[INFO] Initializing OpenDroneMap app - Sat Mar 30 23:37:49 2019
[DEBUG] Loading dataset from: /home/ravindu/Documents/ODMProject/odm_data_aukerman/images
[DEBUG] /home/ravindu/Documents/ODMProject/odm_data_aukerman/images
[DEBUG] Tag not set
[WARNING] Could not find ccd_width in file. Use --force-ccd or edit the sensor_data.json file to manually input ccd width
[DEBUG] Loaded DSC00240.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30348025 | lon: -81.7517445 | alt: 344.061
[DEBUG] Tag not set
[DEBUG] Loaded DSC00309.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039162222 | lon: -81.7523976389 | alt: 340.609
[DEBUG] Tag not set
[DEBUG] Loaded DSC00275.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047684167 | lon: -81.7532261111 | alt: 340.284
[DEBUG] Tag not set
[DEBUG] Loaded DSC00254.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3037130278 | lon: -81.7525375556 | alt: 341.123
[DEBUG] Tag not set
[DEBUG] Loaded DSC00268.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3038360278 | lon: -81.7504509722 | alt: 342.426
[DEBUG] Tag not set
[DEBUG] Loaded DSC00292.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3035873056 | lon: -81.7523199444 | alt: 340.109
[DEBUG] Tag not set
[DEBUG] Loaded DSC00310.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3038811389 | lon: -81.7528799722 | alt: 341.411
[DEBUG] Tag not set
[DEBUG] Loaded DSC00249.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3036291667 | lon: -81.7518736944 | alt: 345.253
[DEBUG] Tag not set
[DEBUG] Loaded DSC00283.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034936111 | lon: -81.7511131667 | alt: 339.037
[DEBUG] Tag not set
[DEBUG] Loaded DSC00300.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3038697222 | lon: -81.75150825 | alt: 341.683
[DEBUG] Tag not set
[DEBUG] Loaded DSC00251.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3044262778 | lon: -81.7518099722 | alt: 339.899
[DEBUG] Tag not set
[DEBUG] Loaded DSC00256.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3038490556 | lon: -81.7515603889 | alt: 341.482
[DEBUG] Tag not set
[DEBUG] Loaded DSC00260.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3041795833 | lon: -81.7524315 | alt: 343.881
[DEBUG] Tag not set
[DEBUG] Loaded DSC00286.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045995 | lon: -81.7515376111 | alt: 339.613
[DEBUG] Tag not set
[DEBUG] Loaded DSC00301.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039381667 | lon: -81.7509873056 | alt: 340.336
[DEBUG] Tag not set
[DEBUG] Loaded DSC00229.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3038215556 | lon: -81.7504664444 | alt: 346.315
[DEBUG] Tag not set
[DEBUG] Loaded DSC00252.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3043779167 | lon: -81.7522945 | alt: 341.061
[DEBUG] Tag not set
[DEBUG] Loaded DSC00271.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3048244167 | lon: -81.7512196667 | alt: 344.397
[DEBUG] Tag not set
[DEBUG] Loaded DSC00297.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3043652222 | lon: -81.7528633333 | alt: 343.766
[DEBUG] Tag not set
[DEBUG] Loaded DSC00305.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3041436944 | lon: -81.7527095833 | alt: 342.815
[DEBUG] Tag not set
[DEBUG] Loaded DSC00233.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30482825 | lon: -81.75177575 | alt: 346.66
[DEBUG] Tag not set
[DEBUG] Loaded DSC00247.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045451944 | lon: -81.7531268611 | alt: 348.357
[DEBUG] Tag not set
[DEBUG] Loaded DSC00303.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3042773056 | lon: -81.7516921667 | alt: 341.629
[DEBUG] Tag not set
[DEBUG] Loaded DSC00242.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039691944 | lon: -81.7507909167 | alt: 343.792
[DEBUG] Tag not set
[DEBUG] Loaded DSC00277.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3040436667 | lon: -81.7539561944 | alt: 340.463
[DEBUG] Tag not set
[DEBUG] Loaded DSC00239.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034251111 | lon: -81.7523136389 | alt: 342.956
[DEBUG] Tag not set
[DEBUG] Loaded DSC00289.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045537778 | lon: -81.7531378889 | alt: 343.726
[DEBUG] Tag not set
[DEBUG] Loaded DSC00279.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.303422 | lon: -81.7531661667 | alt: 339.615
[DEBUG] Tag not set
[DEBUG] Loaded DSC00258.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30423375 | lon: -81.7512890556 | alt: 343.547
[DEBUG] Tag not set
[DEBUG] Loaded DSC00237.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039637222 | lon: -81.7538958889 | alt: 341.525
[DEBUG] Tag not set
[DEBUG] Loaded DSC00304.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3041931667 | lon: -81.7522134167 | alt: 343.973
[DEBUG] Tag not set
[DEBUG] Loaded DSC00261.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3041603611 | lon: -81.7529556667 | alt: 344.167
[DEBUG] Tag not set
[DEBUG] Loaded DSC00272.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047958333 | lon: -81.7517322778 | alt: 344.069
[DEBUG] Tag not set
[DEBUG] Loaded DSC00257.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039471111 | lon: -81.7510318611 | alt: 341.427
[DEBUG] Tag not set
[DEBUG] Loaded DSC00267.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039547778 | lon: -81.7536106944 | alt: 345.784
[DEBUG] Tag not set
[DEBUG] Loaded DSC00296.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3043718611 | lon: -81.7523446111 | alt: 341.207
[DEBUG] Tag not set
[DEBUG] Loaded DSC00293.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3036338611 | lon: -81.7517810833 | alt: 341.2
[DEBUG] Tag not set
[DEBUG] Loaded DSC00276.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047161389 | lon: -81.7537160833 | alt: 341.171
[DEBUG] Tag not set
[DEBUG] Loaded DSC00238.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034077778 | lon: -81.7529882778 | alt: 341.252
[DEBUG] Tag not set
[DEBUG] Loaded DSC00241.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3035039722 | lon: -81.7511898889 | alt: 344.234
[DEBUG] Tag not set
[DEBUG] Loaded DSC00280.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034239722 | lon: -81.7526520833 | alt: 340.463
[DEBUG] Tag not set
[DEBUG] Loaded DSC00284.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3040140556 | lon: -81.7507745556 | alt: 339.438
[DEBUG] Tag not set
[DEBUG] Loaded DSC00294.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3036838611 | lon: -81.7512788889 | alt: 340.891
[DEBUG] Tag not set
[DEBUG] Loaded DSC00236.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047899444 | lon: -81.7533286667 | alt: 347.083
[DEBUG] Tag not set
[DEBUG] Loaded DSC00311.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039436667 | lon: -81.7533781944 | alt: 342.679
[DEBUG] Tag not set
[DEBUG] Loaded DSC00290.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3036917778 | lon: -81.7535909722 | alt: 340.044
[DEBUG] Tag not set
[DEBUG] Loaded DSC00263.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039475833 | lon: -81.7519216667 | alt: 342.4
[DEBUG] Tag not set
[DEBUG] Loaded DSC00255.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3037884722 | lon: -81.7520480556 | alt: 341.924
[DEBUG] Tag not set
[DEBUG] Loaded DSC00278.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034985278 | lon: -81.753889 | alt: 339.912
[DEBUG] Tag not set
[DEBUG] Loaded DSC00274.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047610278 | lon: -81.7527251667 | alt: 340.963
[DEBUG] Tag not set
[DEBUG] Loaded DSC00244.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045837778 | lon: -81.7516030556 | alt: 343.204
[DEBUG] Tag not set
[DEBUG] Loaded DSC00288.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045609444 | lon: -81.7526385 | alt: 340.945
[DEBUG] Tag not set
[DEBUG] Loaded DSC00230.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3041908611 | lon: -81.7504879444 | alt: 344.956
[DEBUG] Tag not set
[DEBUG] Loaded DSC00253.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30440425 | lon: -81.7528406111 | alt: 340.492
[DEBUG] Tag not set
[DEBUG] Loaded DSC00282.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034747778 | lon: -81.7516190833 | alt: 338.813
[DEBUG] Tag not set
[DEBUG] Loaded DSC00259.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30423425 | lon: -81.7518821944 | alt: 344.877
[DEBUG] Tag not set
[DEBUG] Loaded DSC00287.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045933611 | lon: -81.7520926111 | alt: 337.38
[DEBUG] Tag not set
[DEBUG] Loaded DSC00295.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3044201111 | lon: -81.7518385556 | alt: 339.307
[DEBUG] Tag not set
[DEBUG] Loaded DSC00243.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3043352778 | lon: -81.7508072222 | alt: 341.077
[DEBUG] Tag not set
[DEBUG] Loaded DSC00298.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3037210556 | lon: -81.7525345 | alt: 340.667
[DEBUG] Tag not set
[DEBUG] Loaded DSC00273.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3048021667 | lon: -81.7522152222 | alt: 341.268
[DEBUG] Tag not set
[DEBUG] Loaded DSC00285.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3043623333 | lon: -81.7508013333 | alt: 340.333
[DEBUG] Tag not set
[DEBUG] Loaded DSC00246.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045652778 | lon: -81.7526164722 | alt: 346.458
[DEBUG] Tag not set
[DEBUG] Loaded DSC00306.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.303763 | lon: -81.7523508056 | alt: 340.419
[DEBUG] Tag not set
[DEBUG] Loaded DSC00264.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30391725 | lon: -81.7524201111 | alt: 340.872
[DEBUG] Tag not set
[DEBUG] Loaded DSC00299.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3037798333 | lon: -81.7520173611 | alt: 341.222
[DEBUG] Tag not set
[DEBUG] Loaded DSC00308.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039458611 | lon: -81.7524128333 | alt: 338.915
[DEBUG] Tag not set
[DEBUG] Loaded DSC00265.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3038908056 | lon: -81.7525851111 | alt: 342.668
[DEBUG] Tag not set
[DEBUG] Loaded DSC00269.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3041955278 | lon: -81.7505062222 | alt: 343.176
[DEBUG] Tag not set
[DEBUG] Loaded DSC00270.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3045472778 | lon: -81.7504955556 | alt: 343.119
[DEBUG] Tag not set
[DEBUG] Loaded DSC00307.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3039367778 | lon: -81.7519249444 | alt: 341.13
[DEBUG] Tag not set
[DEBUG] Loaded DSC00235.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047649722 | lon: -81.7528027222 | alt: 346.765
[DEBUG] Tag not set
[DEBUG] Loaded DSC00232.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3047985556 | lon: -81.7512516389 | alt: 343.835
[DEBUG] Tag not set
[DEBUG] Loaded DSC00302.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3042734167 | lon: -81.7511605833 | alt: 340.216
[DEBUG] Tag not set
[DEBUG] Loaded DSC00281.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3034368611 | lon: -81.7521256944 | alt: 338.793
[DEBUG] Tag not set
[DEBUG] Loaded DSC00234.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.30475575 | lon: -81.7522948889 | alt: 345.157
[DEBUG] Tag not set
[DEBUG] Loaded DSC00291.JPG | camera: sony dsc-wx220 | dimensions: 4896 x 3672 | focal: 4.45 | ccd: None | lat: 41.3036064167 | lon: -81.7528888056 | alt: 338.335
[INFO] Found 77 usable images
/bin/sh: 1: /home/ravindu/Documents/OpenDroneMap-v0.4/build/bin/odm_extract_utm: not found
[WARNING] Could not find file /home/ravindu/Documents/ODMProject/odm_data_aukerman/odm_georeferencing/coords.txt
[INFO] Running ODM Load Dataset Cell - Finished
[INFO] Running ODM OpenSfM Cell
[WARNING] Found a valid OpenSfM reconstruction file in: /home/ravindu/Documents/ODMProject/odm_data_aukerman/opensfm/reconstruction.json
[WARNING] Found a valid Bundler file in: /home/ravindu/Documents/ODMProject/odm_data_aukerman/opensfm/reconstruction.json
[INFO] Running ODM OpenSfM Cell - Finished
[INFO] Running ODM Meshing Cell
[DEBUG] Writing ODM 2.5D Mesh file in: /home/ravindu/Documents/ODMProject/odm_data_aukerman/odm_meshing/odm_25dmesh.ply
[DEBUG] running /home/ravindu/Documents/OpenDroneMap-v0.4/build/bin/odm_25dmeshing -inputFile /home/ravindu/Documents/ODMProject/odm_data_aukerman/opensfm/reconstruction.ply -outputFile /home/ravindu/Documents/ODMProject/odm_data_aukerman/odm_meshing/odm_25dmesh.ply -logFile /home/ravindu/Documents/ODMProject/odm_data_aukerman/odm_meshing/odm_25dmeshing_log.txt -maxVertexCount 100000 -neighbors 24 -resolution 0
