Hello and thanks for the task you are doing.
I have a question.
1- Is it possible to create a new user but without any processing permission?
I want a user only capable to see some of the projects that I have done, but only the results and the exporting options.
I’ve seen the sharing option has only this limited options, could it be a user login option?
I have WebODM installed on a VM instance on Google Cloud.
3- Is there a posibility to see the 3D (las, obj) in a 3D globe with a terrain basemap, like cesium does?
Would be good to have the results in the display like terriajs that we could add wms and additional data to the results.
I’ve seen the temporal json and shp upload option but is there an option to create lines, polygons and points to 2D map and upload other layers and be able to share them using the sharing option or with this new observer profile?
