Object Isolation Orthomosaic
I’m going to try to make this as specific as possible! I am using drone photos to create orthomosaics, which will be used for engineering. I am trying to create an orthomosaic showing only specific artifacts (ie. only show roads). My plan is to run image segmentation on the original drone photos and anything outside of the boundary I want to mask in some way.
Is there a way for ODM to ignore a certain RGB value, or trick the algorithm to believe the only artifacts it can match is what I specify?
I hope this is clear. Thank you in advance!
There sure is! In 2.0, we have introduced this feature:
Thank you! I will try this out!!
