OATS Improvement Help
I’m over my head here, but I’m trying to see how OATS could be modified to accept dataset links that point to a subfolder of a GitHub repository, instead of needing the “root” zip link. Something more along the lines of how, with the Cloud Import Plugin, we can do the same thing via WebODM GUI.
I believe functions.bash needs to be modified, likely starting from Line 74:
check_download_dataset(){
    dataset="$1"
    if [ ! -e ./datasets/$dataset/images ] && [ ! -z $DATASET_URL ]; then
        if [ ! -e ./datasets/$dataset ]; then
            mkdir ./datasets/$dataset
        fi
        wget $DATASET_URL -q -O ./datasets/$dataset/download.zip
        cd ./datasets/$dataset/
        unzip ./download.zip 2>/dev/null
        rm ./download.zip
        # Remove top level directory if needed
        for dir in $(ls -d */); do
            if [ "$dir" != "images/" ]; then
                mv "$dir"/* .
                rm -fr "$dir"
            fi
        done
        # Check images path
        if [ ! -e ./images ]; then
            mkdir images
            mv *.* images
        fi
        cd ../../
    fi
This link posits this solution:
curl -L https://github.com/janosgyerik/jquery-upvote/tarball/master > project.tar.gz
(I’m trying to get OATS files working for the mf_obriens and mf_old_orchard datasets)
