NVM: Number of features......process stuck?
My process have been here for a while (several hours)…total process time 33 h. Would you say that the process is stuck/hung.
1300 + images.
node-odm-1 (manual)
50GB RAM
CPU 6
[INFO] Starting smoothing…
[INFO] Smoothing iteration 1
[INFO] Completed smoothing to create …/var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/tmp/mesh_dsm.tif in 0:01:53.222566
[INFO] Completed mesh_dsm.tif in 2:29:36.967405
[INFO] Creating mesh from DSM: /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/tmp/mesh_dsm.tif
[INFO] running /code/SuperBuild/src/dem2mesh/dem2mesh -inputFile /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/tmp/mesh_dsm.tif -outputFile /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/odm_25dmesh.dirty.ply -maxTileLength 4000 -maxVertexCount 100000
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/odm_25dmesh.dirty.ply -outputFile /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/odm_25dmesh.ply -removeIslands -decimateMesh 100000
[INFO] Finished odm_meshing stage
[INFO] Running mvs_texturing stage
[INFO] Writing MVS Textured file in: /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_texturing/odm_textured_model.obj
[INFO] running /code/SuperBuild/install/bin/texrecon /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/opensfm/reconstruction.nvm /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_meshing/odm_mesh.ply /var/www/data/f546a976-e8f2-4db5-9c10-8702ff6e779b/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none -n 65535
/code/SuperBuild/install/bin/texrecon (built on Nov 19 2019, 17:31:20)
Load and prepare mesh:
Reading PLY: 79370 verts…
157610 faces…
done.
Warning: Zero-length normals detected: 2 face normals, 461 vertex normals
Generating texture views:
NVM: Loading file…
NVM: Number of features: 1822478
