I am trying to process 1310 images from my Mecasense Micasense rededge camera. For some reason, it’s not processing all bands. Thanks in advance.
[INFO] Fast orthophoto is turned on, automatically setting --skip-3dmodel
[INFO] Initializing ODM - Sat Dec 19 08:24:34 2020
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {‘micasense rededge 1280 960 brown 1.1458 blue’: {‘projection_type’: ‘brown’, ‘width’: 1280, ‘height’: 960, ‘focal_x’: 1.1589626608202381, ‘focal_y’: 1.1589626608202381, ‘c_x’: 0.026384410787813894, ‘c_y’: 0.005679101753941108, ‘k1’: -0.07340217251236827, ‘k2’: 0.07753744027240361, ‘p1’: 0.0009980679310383678, ‘p2’: -0.0012260105725874844, ‘k3’: 0.03545901380030076}, ‘micasense rededge 1280 960 brown 1.1458 green’: {‘projection_type’: ‘brown’, ‘width’: 1280, ‘height’: 960, ‘focal_x’: 1.1573314223704725, ‘focal_y’: 1.1573314223704725, ‘c_x’: 0.003890121046317773, ‘c_y’: 0.002109008131436674, ‘k1’: -0.07486889193429358, ‘k2’: 0.08252170048864226, ‘p1’: 0.0009666814441764056, ‘p2’: -0.0010383507298765099, ‘k3’: 0.03552783181362917}, ‘micasense rededge 1280 960 brown 1.1458 rededge’: {‘projection_type’: ‘brown’, ‘width’: 1280, ‘height’: 960, ‘focal_x’: 1.1597642212804677, ‘focal_y’: 1.1597642212804677, ‘c_x’: -0.003525154610966184, ‘c_y’: 0.008145481915915163, ‘k1’: -0.07737891237197571, ‘k2’: 0.07689628713429875, ‘p1’: 0.00021171960763726925, ‘p2’: -0.0015645923530165457, ‘k3’: 0.034235592463022144}, ‘micasense rededge 1280 960 brown 1.1458 nir’: {‘projection_type’: ‘brown’, ‘width’: 1280, ‘height’: 960, ‘focal_x’: 1.159903942931982, ‘focal_y’: 1.159903942931982, ‘c_x’: 0.021440182651411517, ‘c_y’: 0.011810288927861026, ‘k1’: -0.06046732901782252, ‘k2’: 0.028948954164343066, ‘p1’: 0.0003344640625276322, ‘p2’: -0.0015686553848317413, ‘k3’: -0.0010536688268860733}, ‘micasense rededge 1280 960 brown 1.1458 red’: {‘projection_type’: ‘brown’, ‘width’: 1280, ‘height’: 960, ‘focal_x’: 1.1589486882430866, ‘focal_y’: 1.1589486882430866, ‘c_x’: 0.013873746790016624, ‘c_y’: -0.005741079315444213, ‘k1’: -0.07691144911351784, ‘k2’: 0.07797061334372792, ‘p1’: 0.0012375969417238177, ‘p2’: -0.0016315378282242407, ‘k3’: 0.034571675868073144}}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 10.0
[INFO] dsm: True
[INFO] dtm: True
[INFO] end_with: odm_report
[INFO] fast_orthophoto: True
[INFO] feature_quality: medium
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 4
[INFO] merge: all
[INFO] mesh_octree_depth: 10
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 8a82c5d1-3a75-4b3c-8df9-012c0ca21ed9
[INFO] opensfm_depthmap_method: BRUTE_FORCE
[INFO] orthophoto_png: False
[INFO] orthophoto_resolution: 10.0
[INFO] pc_classify: True
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] primary_band: auto
[INFO] radiometric_calibration: camera+sun
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: [‘dataset’, ‘split’, ‘merge’, ‘opensfm’, ‘openmvs’, ‘odm_filterpoints’, ‘odm_meshing’, ‘mvs_texturing’, ‘odm_georeferencing’, ‘odm_dem’, ‘odm_orthophoto’, ‘odm_report’]
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] sm_cluster: True
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 50
[INFO] split_multitracks: False
[INFO] split_overlap: 30.0
[INFO] texturing_data_term: area
[INFO] texturing_skip_global_seam_leveling: True
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/8a82c5d1-3a75-4b3c-8df9-012c0ca21ed9/images
[INFO] Loading 1310 images
[INFO] Found 1310 usable images
[INFO] Parsing SRS header: WGS84 UTM 10N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Setting max-concurrency to 3 to better handle remote splits
[INFO] Large dataset detected (1310 photos) and split set at 50. Preparing split merge.
[INFO] Reconstruction will use 262 images from auto band
[INFO] Wrote camera_models_overrides.json to OpenSfM directory
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 1280px
======No errors until this below
[INFO] Found 6 submodels with valid orthophotos and cutlines
[INFO] 6 valid orthophoto rasters to merge
app.execute()
File “/code/opendm/types.py”, line 361, in run
File “/code/opendm/types.py”, line 342, in run
File “/code/stages/splitmerge.py”, line 295, in process
orthophoto.merge(all_orthos_and_ortho_cuts, tree.odm_orthophoto_tif, orthophoto_vars)
File “/code/opendm/orthophoto.py”, line 173, in merge
raise ValueError(“Inputs must be at least 4-band rasters”)
ValueError: Inputs must be at least 4-band rasters
