Not happy with task results
I ran a task process to do a 3D map of some land. It was able to finish and the results turned out pretty good but i was wondering if i changed some of the option settings it could look even better. My question is, I used all my credits to run that task, do I need to purchase more credits to rerun that task with a few option changes? I did go to the dashboard and selected edit to change a few options and selected to restart it but it wont go through. It says processing for hours and then says the task isnt available.
Probably! The defaults work pretty good, but they strike a compromise between speed and quality. They are definitely not the highest quality.
Yes, if you process the task with Lightning (webodm.net).
Thank you very much!
