This is the file I received from surveyor. usually i get long lat coordinates but the last two surveyors I worked with last week both gave me “assumed coordinate system” “local coordinate system”
and ODM says…“Unknown projection undefined, please use a proj.4 string or UTM (for example, “WGS84 UTM 11N”) to define the projection.”
is there a code similar to WGS84 that ODM recognizes as custom or local?
GCP Label, Northing, Easting, Elevation
59,6169.5944555858,6468.8269161083,400.7160000000
60,6069.9905220585,6649.3778439549,386.8187770000
61,5987.0245669833,7012.7096492001,326.1902350000
62,5887.2333072082,7438.3027456189,319.2472050000
63,5604.1440108270,7123.2461589308,323.9407800000
64,5677.5043252947,6669.0504706699,338.0509200000
65,5789.3628157910,6043.8848973293,369.1215520000
66,5801.8687345524,5821.5967880792,361.3151190000
67,6150.5426034868,5447.8520975599,390.8503830000
68,6327.3894582740,5066.7947944458,393.6515330000
69,7080.4927353583,5325.6831500793,413.8143700000
70,6892.0829472815,5955.8574242275,432.6887800000
71,6451.0668640904,5817.2726350049,414.1748350000
72,6293.8433482196,6164.9844632685,428.4066710000
73,6169.5940588467,6468.8266001603,400.7156640000
Thank You!
