If the computer has multiple GPUs does NodeODM:GPU use them, or does it only use one GPU?
Only one currently (but we’d welcome contributions to add support for more!)
When you have multiple GPUs, is there a way to tell NodeODM:GPU to use a specific GPU?
I just added a 12GB GPU to test, but nodeodm:gpu always chooses the 3GB GPU…I took a guess and tried --gpus 0 and --gpus 1 command line options but it had no effect.
Support for multiple GPUs needs some work; feature extraction just chooses the first one, whereas OpenMVS tries to pick the fastest card (not sure if it guesses correctly all of the times).
I’ll figure out a way to log the utilisation of each GPU and run a test to see if it uses only the GeForce GPU or uses the Tesla GPU at any stage.
Ok test completed - it only used the GeForce GPU, didn’t touch the Tesla GPU.
I found a way to disable GPUs so WebODM/NodeODM uses the GPU you want it to.
- Find out the PCI device ID of the GPU to be disabled:
[email protected]:~$ lspci
0a:00.0 3D controller: NVIDIA Corporation GK180GL [Tesla K40c] (rev a1)
0b:00.0 VGA compatible controller: NVIDIA Corporation GP106 [GeForce GTX 1060 3GB] (rev a1)
0b:00.1 Audio device: NVIDIA Corporation GP106 High Definition Audio Controller (rev a1) - Use nvidia-ami to get GPU ID numbers:
[email protected]:~$ nvidia-smi -L
GPU 0: Tesla K40c (UUID: GPU-e8ecfe9b-eccf-5827-772f-650ef8298262)
GPU 1: NVIDIA GeForce GTX 1060 3GB (UUID: GPU-505500e5-1f86-dfb9-1d33-2fce6d27c118) - Disable persistence mode for the desired GPU:
[email protected]:~$ nvidia-smi -i 1 -pm 0
Persistence mode is already Disabled for GPU 00000000:0B:00.0.
All done. - Disable the desired GPU:
[email protected]:~$ sudo nvidia-smi drain -p 0000:0B:00.0 -m 1
Successfully set GPU 00000000:0B:00.0 drain state to: draining. - Check only the desired GPU is available now:
GPU 0: Tesla K40c (UUID: GPU-e8ecfe9b-eccf-5827-772f-650ef8298262) - When you want to re-enable the other GPU(s):
[email protected]:~$ sudo nvidia-smi drain -p 0000:0B:00.0 -m 0
Successfully set GPU 00000000:0B:00.0 drain state to: not draining.
