NodeODM, docker and s3
It’s me again. I am still learning and testing the various and amazing tools at our disposition.
I tried to add and s3 (a space from DigitalOcean), it works like a charm on the windows NodeODM exe but when I add the --s3_endpoint parameter to my docker line I have the following error : unknown flag: --s3_endpoint.
My docker line is the following :
docker run -p 3000:3000 --s3_endpoint myendpoint.fra1.digitaloceanspaces.com --s3_bucket myBucket --s3_access_key myAccess --s3_secret_key myKey --s3_upload_everything opendronemap/nodeodm
Am I missing something ?
Try:
docker run -p 3000:3000 opendronemap/nodeodm --s3_endpoint myendpoint.fra1.digitaloceanspaces.com --s3_bucket myBucket --s3_access_key myAccess --s3_secret_key myKey --s3_upload_everything
Thank you, it worked.
I should have try to permute the parameters…
Sorry for this.
I had try this command line based on the README.md of NodeODM equivalent for gpu.
docker run -p 3000:3000 --gpus all opendronemap/nodeodm:gpu
Should the readme be updated ?
That command is correct; the --gpus parameter is a docker parameter, so goes before the image name.
