Hi all,
I’m new here, and some things might be very obvious to you but alien to me. I have already searched for this particular behavior on the forum, but not found anything.
I’ve used WebODM successfully for a little while, and installed an accessible node on a second machine. Now I’ve tried installing NodeMICMAC on my main machine. However, I am not getting any results when using it, it seems to work full speed forever.
I am testing with a dataset from the Pix4D tutorial, which contains 13 geotagged images and one GCP-file edited to the WebODM format. I’ve used it for benchtesting the WebODM settings and nodes on the different machines, running successfully at ca 8min and 25min using default and High Resolution settings on the normal nodes. When trying NodeMICMAC, all cores are engaged and it has currently been running for almost 35hrs - which seems excessive for a 13 photo dataset.
I previously tried a different set with geotags, but no GCP file, and ended it after 8hrs - Edit: for clarity: It never finished, I ended the process because I needed to use the PC for something else.
It does not seem to be doing an infinite loop, or stopped processing, as the log output still changes.
Has anyone else seen similar behavior?
The latest output looks like this, there is other information occasionally, the bracketed numbers change - it is also down to 11 Images loaded from yesterday:
TCor 3585.41 CTimeC 11.5863 TOpt 1679.06 Pts , R2 0, RN 0 Pts , R-GEN 99.9937, Isol 0.00627367 PT 3.09452e+08
DO ONE BLOC [5043,9480] [5119,9560] [5005,9442] MATP 0
11 Images Loaded
Correl Calc, Begin Opt
TCor 3692.36 CTimeC 11.5683 TOpt 1743.23 Pts , R2 0, RN 0 Pts , R-GEN 99.9937, Isol 0.00630553 PT 3.1918e+08
DO ONE BLOC [5119,9480] [5196,9560] [5081,9442] MATP 0
11 Images Loaded
TCor 3792.01 CTimeC 11.5819 TOpt 1796.94 Pts , R2 0, RN 0 Pts , R-GEN 99.9935, Isol 0.00650653 PT 3.27409e+
