Nodejs new task exmaple
Hello guys. Can you help me with my problem?
I want to create new tasks in WebODM from nodejs server. So i have urls with images, i download them into my nodejs server and then create POST request to webodm api. And it returns only “Bad request”. And I don’t even know how to figure out it, how to debug django framework API or something else, cause i’m not a python developer.
Maybe if somebody can provide some example, how to upload images from nodejs server, it helps me
Thank you.
Hey @shoudaos :hand: see if this helps. nodeodm-proxy/proxy.js at master · MasseranoLabs/nodeodm-proxy · GitHub
It’s an example of upload to the NodeODM API, but should work similarly (although not identically) for the WebODM API.
This may also help as it documents a bit of the WebODM API, albeit with python examples: https://docs.webodm.org/
Thank you for this reference. But I want to ask if you know maybe what is wrong with my code?
For making requests I use “request” lib for nodejs.
Here it is:
    const request = require("request");
    let requestSettings = {
        method: "GET"
    let promises = [];
    // Here I download images from urls:
    images.map((image) => {
        requestSettings.url = "http:" + image;
        promises.push(new Promise((resolve, reject) => {
            request(requestSettings, function (error, response, data) {
                if (error) {
                    reject(error);
                if (response.statusCode !== 200) {
                    reject("Invalid status code <" + response.statusCode + ">");
                resolve(data);
    Promise.all(promises).then(images => {
        startTask(projectId, images);
    // Here I'm preparing the new task:
function startTask(projectId, images) {
    const opts = {
        url: `http://${hostname}:${port}/api/projects/${projectId}/tasks/`,
        method: "POST",
        json: true,
        formData: {
            // Here I just hardcoded the data for testing
            "images[0]": images[0],
            "images[1]": images[1],
            "images[2]": images[2],
            "name": "Task of 2019 - 01 - 21T13: 12:43.474Z",
            "processing_node": "1",
            "auto_processing_node": "true",
            "resize_to": "2048",
            "options[name]": "dsm",
            "options[value]": "true"
        headers: {
            "Authorization": `JWT ${process.env.ODM_TOKEN}`
    request(opts, (err, httpResponse, body) => {
        console.log(err, httpResponse, body);
So the response comes with status 400: Bad Request
