Nodegpu on windows failed with
nvidia-smi not found in PATH, using CPU
[INFO] running “/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud” “/var/www/data/c9f8a570-caf0-4a57-8f36-fec15333de54/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 3 --dense-config-file “/var/www/data/c9f8a570-caf0-4a57-8f36-fec15333de54/opensfm/undistorted/openmvs/Densify.ini” --max-resolution 4000 --max-threads 2 --number-views-fuse 2 --sub-resolution-levels 2 -w “/var/www/data/c9f8a570-caf0-4a57-8f36-fec15333de54/opensfm/undistorted/openmvs/depthmaps” -v 0 --cuda-device -2
/code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud: error while loading shared libraries: libcuda.so.1: cannot open shared object file: No such file or directory
Child returned 127
File “/code/stages/odm_app.py”, line 81, in execute
File “/code/opendm/types.py”, line 386, in run
File “/code/opendm/types.py”, line 365, in run
File “/code/stages/openmvs.py”, line 117, in process
raise e
File “/code/stages/openmvs.py”, line 103, in process
run_densify()
File “/code/stages/openmvs.py”, line 99, in run_densify
system.run(‘“%s” “%s” %s’ % (context.omvs_densify_path,
File “/code/opendm/system.py”, line 109, in run
opendm.system.SubprocessException: Child returned 127
I’m not one of the WebODM gurus but it looks like you’re missing the Nvidia CUDA drivers and/or toolkit:
