Node-odm-1 offline error
Browser: Chrome
OS: Windows 10 Pro
Install Process:
  1. Installed Git
  2. Installed Python 3.7 with Add Python.3.X to PATH checked
  3. Installed Docker from https://download.docker.com/win/stable/Docker%20for%20Windows%20Installer.exe
4.Allocated half of the CPUs (2) to Docker and 70+ percent memory
5.Used Git GUI to clone the repository at https://github.com/OpenDroneMap/WebODM
and ran ./webodm.sh start in Git Bash
At localhost:8000, WebODM was running. I created a login then attempted to upload some images. I received an error asking me to check permissions. I applied the all available permissions to my login, group (Default), and the node. Attempted to upload the same images again and received the same error regarding the node. When I check the node, it says it is offline.
Did a docker rebuild and reboot, now WebODM won’t start up on the localhost at all, though it appears to start fine:
$ ./webodm.sh start
Checking for docker...   OK
Checking for git...   OK
Checking for docker-compose...   OK
Starting WebODM...
Host: localhost
Port: 8000
Media directory: appmedia
SSL: NO
SSL key:
SSL certificate:
Celery Broker: redis://broker
Default Nodes: 1
Starting node-odm ... done
Starting broker   ... done
Starting db       ... done
Starting worker   ... done
Starting webapp   ... done
Try ./webodm.sh --restart.
