Node-odm-1 constantly goes offline
I previously performed a standard install of WebODM and processed several datasets with no issues. I recently upgraded to the latest version, WebODM 1.9.15, and have not been able to successfully process any subsequent datasets. Most of the problems seem to relate to Processing Node, node-odm-1, going offline. The color goes from black to red.
Below are the specs on my Windows PC.
  • Windows 10 Professional (x64) Version 2009 (build 19043.1889)
  • 65448 Megabytes Usable Installed Memory
  • ASUSTeK COMPUTER INC. TUF GAMING X570-PRO (WI-FI) Rev X.0x
  • 3.70 gigahertz AMD Ryzen 9 5900X 12-Core
    No memory cache
    64-bit ready
    Multi-core (12 total)
    Hyper-threaded (24 total)
  • NVIDIA GeForce RTX 3070 Ti [Display adapter]
All internal drives are SSD drives.
Network connection is 1GB fiber. Per Ookla Speedtest: Ping 4ms, Download speed is 241Mbps, and Upload 423Mbps.
Below are some recent messages that have appeared.
Processing node went offline. This could be due to insufficient memory or a network error.
Connection error: HTTPConnectionPool(host=‘127.0.0.1’, port=29301): Max retries exceeded with url: /info?token=Pw8hWHKtBhYGfv (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x0000024A2BB59910>: Failed to establish a new connection: [Errno 10061] WSAECONNREFUSED’))
Any suggestions?
