No start anymore after Update - Error: Update exited with code: 1
Hello!
Sorry that I am writing already again even the “Child returned 139” issue isn’t solved yet. But I thought that morning - okay let’s update again. First the Console showed that all the update went well but than I tried to start and a error occured. So I thought maybe something went wrong and I pushed again the Update bottom but now another Error occured:
  • D:\WebODM Manager>cd WebODM/
  • D:\WebODM Manager\WebODM>git pull origin master
  • Stopping node-odm-1 …
  • Stopping db …
  • Stopping broker …
  • From https://github.com/OpenDroneMap/WebODM
    • branch master -> FETCH_HEAD
  • e[3Ae[2K
  • Stopping node-odm-1 … e[32mdonee[0m
  • Updating 3714f43…a02b20a
  • error: Your local changes to the following files would be overwritten by merge:
  • Dockerfile
  • README.md
  • app/api/processingnodes.py
  • app/api/tasks.py
  • app/boot.py
  • app/migrations/0001_initial.py
  • app/models/preset.py
  • app/models/project.py
  • app/models/task.py
  • app/plugins/signals.py
  • app/static/app/css/theme.scss
  • app/static/app/js/classes/AssetDownloads.js
  • app/static/app/js/classes/plugins/API.js
  • app/static/app/js/classes/plugins/ApiFactory.js
  • app/static/app/js/classes/plugins/Dashboard.js
  • app/static/app/js/components/BasicTaskView.jsx
  • app/static/app/js/components/EditTaskForm.jsx
  • app/static/app/js/components/Map.jsx
  • app/static/app/js/components/NewTaskPanel.jsx
  • app/static/app/js/components/ProjectListItem.jsx
  • app/static/app/js/components/TaskListItem.jsx
  • app/static/app/js/css/Map.scss
  • app/static/app/js/main.jsx
  • app/templates/app/processing_node.html
  • app/tests/test_api.py
  • app/tests/test_api_preset.py
  • app/tests/test_api_task.py
  • app/tests/test_app.py
  • nodeodm/admin.py
  • nodeodm/api_client.py
  • nodeodm/migrations/0001_initial.py
  • nodeodm/models.py
  • package.json
  • requirements.txt
  • slate/source/includes/reference/_processingnode.md
  • webodm/settings.py
  • Please commit your changes or stash them before you merge.
  • error: The following untracked working tree files would be overwritten by merge:
  • app/migrations/0024_update_task_assets.py
  • app/static/app/js/classes/TempLayer.js
  • app/static/app/js/classes/plugins/App.js
  • app/tests/test_gdal.py
  • nodeodm/migrations/0005_auto_20190115_1346.py
  • plugins/lightning/init.py
  • plugins/lightning/manifest.json
  • plugins/lightning/plugin.py
  • plugins/lightning/public/CostEstimateItem.jsx
  • plugins/lightning/public/CostEstimateItem.scss
  • plugins/lightning/public/Dashboard.jsx
  • plugins/lightning/public/Dashboard.scss
  • plugins/lightning/public/Login.jsx
  • plugins/lightning/public/Login.scss
  • plugins/lightning/public/add_cost_estimate.js
  • plugins/lightning/public/app.jsx
  • plugins/lightning/public/app.scss
  • plugins/lightning/templates/index.html
  • Please move or remove them before you merge.
  • Aborting
  • D:\WebODM Manager\WebODM>docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml down --remove-orphans
  • e[3Be[1Ae[2K
  • Stopping broker … e[32mdonee[0m
  • e[1Be[2Ae[2K
  • Stopping db … e[32mdonee[0m
  • e[2B
  • Removing node-odm-1 …
  • Removing db …
  • Removing broker …
  • e[3Ae[2K
  • Removing node-odm-1 … e[32mdonee[0m
  • e[3Be[1Ae[2K
  • Removing broker … e[32mdonee[0m
  • e[1Be[2Ae[2K
  • Removing db … e[32mdonee[0m
  • e[2BRemoving network webodm_default
  • D:\WebODM Manager\WebODM>docker-compose -f docker-compose.yml -f docker-compose.nodeodm.yml pull
  • Pulling db (opendronemap/webodm_db:latest)…
  • Get https://registry-1.docker.io/v2/opendronemap/webodm_db/manifests/latest: Get https://auth.docker.io/token?scope=repository%3Aopendronemap%2Fwebodm_db%3Apull&service=registry.docker.io: dial tcp: lookup auth.docker.io on 10.0.2.3:53: read udp 10.0.2.15:33560->10.0.2.3:53: i/o timeout
  • D:\WebODM Manager\WebODM>exit 1
  • Error: Update exited with code: 1
Is this “only” a update problem or do I get deeper into a 1/0-Sh** by updateing a not proper working version?
Tnx for help,
Alex
DId you change any of the files in C:\WebODM Manager\WebODM? it’s really odd you’re getting this error.
Try to delete the C:\WebODM Manager\WebODM folder and restart the program.
arg …
I probably answered to the wrong post when I wanted to answer to this (and I don’t find the way to delete is) - sorry…:
Okay - solved (?) - after some time I updated again and I was able to start WebODM :slight_smile:
