No Processing Nodes Available
Downloaded several sets of images from the website.
Started webodm and it works. Yay!
However, when I try to start processing even Brighton Beach with only 18 pictures, I get the “No processing nodes available” error message. I tried using localhost:8000 but that didn’t work. Any ideas, guys?
Thanks.
Sounds like something didn’t start properly. From your other posts I gather you are running a native installation or compiling it locally, which is not for the faint of heart. Using the docker installation prevents 98% of those headaches. Is the docker install an option for you?
This is not on the development machine. It’s on a separate machine so that I can run it “the normal way,” see the program(s) flow, and get profiles.
Thanks.
P.S. Tried “auto” as a processing node but it sure didn’t like that!
