Without any changes the utility is in the metric mode however being in the states sorry to say we are stuck with the English system.
Which utility in specific? Do you need the final output products in US/Imperial units?
If so, you can set a different CRS for image products in the Map View and export from there.
Thank you very much Sanjin for getting back to my posting. I am using Webodm lightning. And overall I have to say yes to everything that I do in terms of linear measurements, areas and volumes, as well as all reports being reported to me in the English system.
We do not currently support end-to-end units of US/Imperial. Things like the report will be in UTM (meters).
Thank you Saijin for the response. If possible can you add that request as a suggestion for improvement? Thank you kindly.
Feel free to comment regarding your desire to see this feature the issue in the repository where it is tracked:
