I figured it out that it has to do with memory settings, and I found them on the docker and increased disk and memory allocation. That fixed the problem but I doubt most users would go that far trying to figure it out.
It would help to include some decent memory settings on the install by default so that this doesn’t happen. Just a suggestion.
Agreed. Would you be able to add to docs.opendronemap.org? The approximate memory needs for different size datasets is available here, though for an intro user, I would double these memory values for a given dataset size:
