New user question - strange error even with aukerman image set
Hi all,
I’m a new user trying to get up and running. I installed WebODM on a Windows machine w/ 16 GB RAM and completed a small test flight, wanting to stitch together 20 photos with 80% overlap. I tried several of the predefined parameter sets, but keep receiving the “Uh oh, processing stopped because of strange values…” error. Example output pasted below.
I assumed my pictures were bad so I went ahead and downloaded the aukerman photo set and tried with those. I received the same errors.
I’m most interested in the orthophoto for mapping for a research project. I don’t really need 3D, point clouds, etc. if that matters. Any help would be greatly appreciated!
[INFO] Fast orthophoto is turned on, automatically setting --skip-3dmodel
[INFO] Initializing ODM - Wed Nov 24 13:31:32 2021
[INFO] ==============
[INFO] auto_boundary: False
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: True
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: True
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] name: 81851fa5-b272-4a3b-8832-cd22f230c95e
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: True
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\images
[INFO] Loading 6 images
[INFO] Wrote images database: C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\images.json
[INFO] Found 6 usable images
[INFO] Parsing SRS header: WGS84 UTM 16N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Writing exif overrides
[INFO] Maximum photo dimensions: 5472px
[INFO] Photo dimensions for feature extraction: 2736px
[INFO] [‘use_exif_size: no’, ‘flann_algorithm: KDTREE’, ‘feature_process_size: 2736’, ‘feature_min_frames: 8000’, ‘processes: 8’, ‘matching_gps_neighbors: 8’, ‘matching_gps_distance: 0’, ‘optimize_camera_parameters: yes’, ‘undistorted_image_format: tif’, ‘bundle_outlier_filtering_type: AUTO’, ‘sift_peak_threshold: 0.066’, ‘align_orientation_prior: vertical’, ‘triangulation_type: ROBUST’, ‘retriangulation_ratio: 2’, ‘matcher_type: FLANN’, ‘feature_type: SIFT’, ‘use_altitude_tag: yes’, ‘align_method: auto’, ‘local_bundle_radius: 0’]
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm extract_metadata “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
2021-11-24 13:31:34,287 INFO: Extracting EXIF for DJI_0011.JPG
2021-11-24 13:31:34,347 INFO: Extracting EXIF for DJI_0012.JPG
2021-11-24 13:31:34,412 INFO: Extracting EXIF for DJI_0013.JPG
2021-11-24 13:31:34,469 INFO: Extracting EXIF for DJI_0014.JPG
2021-11-24 13:31:34,526 INFO: Extracting EXIF for DJI_0015.JPG
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm detect_features “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
2021-11-24 13:31:35,938 INFO: Capping memory usage to ~ 4257.74609375 MB
2021-11-24 13:31:35,938 INFO: Expecting to process 66 images.
2021-11-24 13:31:35,947 INFO: Reading data for image DJI_0010.JPG (queue-size=0
2021-11-24 13:31:35,947 INFO: Reading data for image DJI_0012.JPG (queue-size=0
2021-11-24 13:31:35,947 INFO: Reading data for image DJI_0014.JPG (queue-size=0
2021-11-24 13:31:36,331 INFO: Reading data for image DJI_0013.JPG (queue-size=1
2021-11-24 13:31:36,332 INFO: Extracting ROOT_SIFT features for image DJI_0012.JPG
2021-11-24 13:31:36,352 DEBUG: Computing sift with threshold 0.066
2021-11-24 13:31:36,411 INFO: Reading data for image DJI_0015.JPG (queue-size=1
2021-11-24 13:31:36,411 INFO: Reading data for image DJI_0011.JPG (queue-size=1
2021-11-24 13:31:36,412 INFO: Extracting ROOT_SIFT features for image DJI_0014.JPG
2021-11-24 13:31:36,412 INFO: Extracting ROOT_SIFT features for image DJI_0010.JPG
2021-11-24 13:31:36,443 DEBUG: Computing sift with threshold 0.066
2021-11-24 13:31:36,926 INFO: Extracting ROOT_SIFT features for image DJI_0013.JPG
2021-11-24 13:31:36,956 DEBUG: Computing sift with threshold 0.066
2021-11-24 13:31:37,048 INFO: Extracting ROOT_SIFT features for image DJI_0015.JPG
2021-11-24 13:31:37,075 INFO: Finished reading images
2021-11-24 13:31:37,076 INFO: Extracting ROOT_SIFT features for image DJI_0011.JPG
2021-11-24 13:31:37,082 DEBUG: Computing sift with threshold 0.066
2021-11-24 13:31:37,118 DEBUG: Computing sift with threshold 0.066
2021-11-24 13:31:39,186 DEBUG: Found 20010 points in 2.7425737380981445s
2021-11-24 13:31:39,186 DEBUG: done
2021-11-24 13:31:39,538 DEBUG: Found 45447 points in 3.1855828762054443s
2021-11-24 13:31:39,538 DEBUG: done
2021-11-24 13:31:40,155 DEBUG: Found 53949 points in 3.711575984954834s
2021-11-24 13:31:40,156 DEBUG: done
2021-11-24 13:31:40,567 DEBUG: Found 51186 points in 3.6105797290802s
2021-11-24 13:31:40,567 DEBUG: done
2021-11-24 13:31:40,618 DEBUG: Found 32148 points in 3.4985272884368896s
2021-11-24 13:31:40,618 DEBUG: done
2021-11-24 13:31:40,943 DEBUG: Found 48015 points in 3.8595237731933594s
2021-11-24 13:31:40,944 DEBUG: done
2021-11-24 13:31:42,382 DEBUG: No segmentation for DJI_0010.JPG, no features masked.
2021-11-24 13:31:44,760 DEBUG: No segmentation for DJI_0012.JPG, no features masked.
2021-11-24 13:31:44,773 DEBUG: No segmentation for DJI_0011.JPG, no features masked.
2021-11-24 13:31:45,561 DEBUG: No segmentation for DJI_0014.JPG, no features masked.
2021-11-24 13:31:45,770 DEBUG: No segmentation for DJI_0013.JPG, no features masked.
2021-11-24 13:31:45,899 DEBUG: No segmentation for DJI_0015.JPG, no features masked.
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm match_features “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
2021-11-24 13:31:49,486 INFO: Matching 15 image pairs
2021-11-24 13:31:49,486 INFO: Computing pair matching with 8 processes
2021-11-24 13:31:49,884 DEBUG: No segmentation for DJI_0012.JPG, no features masked.
2021-11-24 13:31:49,885 DEBUG: No segmentation for DJI_0012.JPG, no features masked.
2021-11-24 13:31:49,941 DEBUG: No segmentation for DJI_0015.JPG, no features masked.
2021-11-24 13:31:49,972 DEBUG: No segmentation for DJI_0014.JPG, no features masked.
2021-11-24 13:31:49,996 DEBUG: No segmentation for DJI_0013.JPG, no features masked.
2021-11-24 13:31:50,198 DEBUG: No segmentation for DJI_0010.JPG, no features masked.
2021-11-24 13:31:50,219 DEBUG: No segmentation for DJI_0011.JPG, no features masked.
2021-11-24 13:31:55,707 DEBUG: Matching DJI_0012.JPG and DJI_0014.JPG. Matcher: FLANN (symmetric) T-desc: 6.158 T-robust: 0.032 T-total: 6.209 Matches: 3954 Robust: 3919 Success: True
2021-11-24 13:31:56,365 DEBUG: Matching DJI_0015.JPG and DJI_0011.JPG. Matcher: FLANN (symmetric) T-desc: 6.862 T-robust: 0.003 T-total: 6.866 Matches: 372 Robust: 326 Success: True
2021-11-24 13:31:56,852 DEBUG: Matching DJI_0012.JPG and DJI_0015.JPG. Matcher: FLANN (symmetric) T-desc: 7.328 T-robust: 0.008 T-total: 7.352 Matches: 1248 Robust: 1203 Success: True
2021-11-24 13:31:56,855 DEBUG: Matching DJI_0013.JPG and DJI_0010.JPG. Matcher: FLANN (symmetric) T-desc: 7.344 T-robust: 0.003 T-total: 7.356 Matches: 536 Robust: 505 Success: True
2021-11-24 13:31:57,098 DEBUG: Matching DJI_0014.JPG and DJI_0010.JPG. Matcher: FLANN (symmetric) T-desc: 7.596 T-robust: 0.002 T-total: 7.599 Matches: 191 Robust: 160 Success: True
2021-11-24 13:31:57,579 DEBUG: Matching DJI_0012.JPG and DJI_0011.JPG. Matcher: FLANN (symmetric) T-desc: 8.017 T-robust: 0.041 T-total: 8.080 Matches: 6802 Robust: 6761 Success: True
2021-11-24 13:31:58,211 DEBUG: Matching DJI_0014.JPG and DJI_0015.JPG. Matcher: FLANN (symmetric) T-desc: 8.492 T-robust: 0.137 T-total: 8.712 Matches: 13843 Robust: 13799 Success: True
2021-11-24 13:31:58,431 DEBUG: Matching DJI_0012.JPG and DJI_0013.JPG. Matcher: FLANN (symmetric) T-desc: 8.802 T-robust: 0.082 T-total: 8.913 Matches: 9086 Robust: 9050 Success: True
2021-11-24 13:31:58,815 DEBUG: Matching DJI_0010.JPG and DJI_0011.JPG. Matcher: FLANN (symmetric) T-desc: 1.924 T-robust: 0.022 T-total: 1.962 Matches: 3853 Robust: 3819 Success: True
2021-11-24 13:31:59,259 DEBUG: Matching DJI_0012.JPG and DJI_0010.JPG. Matcher: FLANN (symmetric) T-desc: 2.389 T-robust: 0.010 T-total: 2.404 Matches: 1384 Robust: 1354 Success: True
2021-11-24 13:31:59,462 DEBUG: Matching DJI_0015.JPG and DJI_0013.JPG. Matcher: FLANN (symmetric) T-desc: 3.702 T-robust: 0.025 T-total: 3.754 Matches: 4614 Robust: 4581 Success: True
2021-11-24 13:31:59,472 DEBUG: Matching DJI_0013.JPG and DJI_0011.JPG. Matcher: FLANN (symmetric) T-desc: 3.053 T-robust: 0.044 T-total: 3.107 Matches: 3139 Robust: 3106 Success: True
2021-11-24 13:31:59,937 DEBUG: Matching DJI_0015.JPG and DJI_0010.JPG. Matcher: FLANN (symmetric) T-desc: 2.329 T-robust: 0.028 T-total: 2.358 Matches: 41 Robust: 10 Success: False
2021-11-24 13:32:00,164 DEBUG: Matching DJI_0014.JPG and DJI_0011.JPG. Matcher: FLANN (symmetric) T-desc: 3.059 T-robust: 0.003 T-total: 3.064 Matches: 1260 Robust: 1223 Success: True
2021-11-24 13:32:01,025 DEBUG: Matching DJI_0014.JPG and DJI_0013.JPG. Matcher: FLANN (symmetric) T-desc: 2.772 T-robust: 0.024 T-total: 2.814 Matches: 11803 Robust: 11778 Success: True
2021-11-24 13:32:01,026 INFO: Matched 15 pairs (brown-brown: 15) in 11.5414658 seconds (0.7694310866666666 seconds/pair).
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
2021-11-24 13:32:02,958 INFO: reading features
2021-11-24 13:32:03,878 DEBUG: Merging features onto tracks
2021-11-24 13:32:04,500 DEBUG: Good tracks: 34949
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
2021-11-24 13:32:09,623 INFO: Starting incremental reconstruction
2021-11-24 13:32:10,120 INFO: Starting reconstruction with DJI_0013.JPG and DJI_0014.JPG
2021-11-24 13:32:10,524 INFO: Two-view reconstruction inliers: 12330 / 12331
2021-11-24 13:32:11,763 INFO: Triangulated: 12330
2021-11-24 13:32:17,128 DEBUG: Ceres Solver Report: Iterations: 37, Initial cost: 6.748142e+01, Final cost: 4.325110e+01, Termination: CONVERGENCE
2021-11-24 13:32:17,370 INFO: Removed outliers: 270
2021-11-24 13:32:17,563 INFO: -------------------------------------------------------
2021-11-24 13:32:17,666 INFO: DJI_0015.JPG resection inliers: 5155 / 5155
2021-11-24 13:32:17,743 INFO: Adding DJI_0015.JPG to the reconstruction
2021-11-24 13:32:18,597 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-24 13:32:21,126 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 1.445030e+02, Final cost: 1.053511e+02, Termination: CONVERGENCE
2021-11-24 13:32:21,569 INFO: Removed outliers: 352
2021-11-24 13:32:21,606 INFO: -------------------------------------------------------
2021-11-24 13:32:21,701 INFO: DJI_0012.JPG resection inliers: 5001 / 5001
2021-11-24 13:32:21,768 INFO: Adding DJI_0012.JPG to the reconstruction
2021-11-24 13:32:22,288 INFO: Re-triangulating
2021-11-24 13:32:22,289 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-24 13:32:24,984 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 1.946521e+02, Final cost: 1.516455e+02, Termination: CONVERGENCE
2021-11-24 13:32:31,970 DEBUG: Ceres Solver Report: Iterations: 10, Initial cost: 2.314512e+02, Final cost: 1.594343e+02, Termination: CONVERGENCE
2021-11-24 13:32:32,714 INFO: Removed outliers: 708
2021-11-24 13:32:32,773 INFO: -------------------------------------------------------
2021-11-24 13:32:32,877 INFO: DJI_0011.JPG resection inliers: 4010 / 4014
2021-11-24 13:32:32,946 INFO: Adding DJI_0011.JPG to the reconstruction
2021-11-24 13:32:33,432 INFO: -------------------------------------------------------
2021-11-24 13:32:33,469 INFO: DJI_0010.JPG resection inliers: 1792 / 1795
2021-11-24 13:32:33,498 INFO: Adding DJI_0010.JPG to the reconstruction
2021-11-24 13:32:33,803 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-24 13:32:37,656 DEBUG: Ceres Solver Report: Iterations: 10, Initial cost: 2.789173e+02, Final cost: 2.146403e+02, Termination: CONVERGENCE
2021-11-24 13:32:38,442 INFO: Removed outliers: 522
2021-11-24 13:32:38,496 INFO: -------------------------------------------------------
2021-11-24 13:32:38,497 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-24 13:32:41,911 DEBUG: Ceres Solver Report: Iterations: 10, Initial cost: 2.023757e+02, Final cost: 2.014756e+02, Termination: CONVERGENCE
2021-11-24 13:32:42,844 INFO: Removed outliers: 5
2021-11-24 13:32:43,290 INFO: Reconstruction 0: 6 images, 34546 points
2021-11-24 13:32:43,291 INFO: 1 partial reconstructions in total.
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm compute_statistics --diagram_max_points 100000 “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
2021-11-24 13:32:53,456 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x0000020322270DC0>
2021-11-24 13:32:53,456 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x0000020322270DC0> on colorbar
2021-11-24 13:32:53,456 DEBUG: Setting pcolormesh
2021-11-24 13:32:54,485 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x000002031C5672E0>
2021-11-24 13:32:54,485 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x000002031C5672E0> on colorbar
2021-11-24 13:32:54,485 DEBUG: Setting pcolormesh
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_geocoords --reconstruction --proj “+proj=utm +zone=16 +datum=WGS84 +units=m +no_defs +type=crs” --offset-x 709033.0 --offset-y 3781573.0 “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
[INFO] Updating C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm\config.yaml
[INFO] undistorted_image_max_size: 787
[INFO] Undistorting C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm …
2021-11-24 13:33:12,580 DEBUG: Undistorting image DJI_0013.JPG
2021-11-24 13:33:12,580 DEBUG: Undistorting image DJI_0014.JPG
2021-11-24 13:33:12,580 DEBUG: Undistorting image DJI_0015.JPG
2021-11-24 13:33:12,580 DEBUG: Undistorting image DJI_0012.JPG
2021-11-24 13:33:12,580 DEBUG: Undistorting image DJI_0011.JPG
2021-11-24 13:33:12,581 DEBUG: Undistorting image DJI_0010.JPG
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_visualsfm --points “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_ply --no-cameras --point-num-views “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm”
[INFO] Finished opensfm stage
[INFO] Filtering C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\opensfm\reconstruction.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] running pdal pipeline -i “C:\Users\dcivite\AppData\Local\Temp\tmpb9uzjx8h.json”
[INFO] Writing ODM 2.5D Mesh file in: C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\odm_25dmesh.ply
[INFO] ODM 2.5D DSM resolution: 0.05
[INFO] Created temporary directory: C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp
[INFO] running pdal info “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_filterpoints\point_cloud.ply” > “C:\Users\dcivite\AppData\Local\Temp\tmp7wfomvgd.json”
[INFO] Point cloud bounds are [minx: -21.68789673, maxx: 12.36624432] [miny: -12.98244095, maxy: 14.71422291]
[INFO] DEM resolution is (554, 682), max tile size is 4096, will split DEM generation into 1 tiles
[INFO] Generating C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\mesh_dsm_r0.14142135623730953_x0_y0.tif (max, radius: 0.14142135623730953, resolution: 0.05)
[INFO] running pdal pipeline -i “C:\Users\dcivite\AppData\Local\Temp\tmp00c4tt98.json”
[INFO] running gdalbuildvrt -input_file_list “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles_list.txt” “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.vrt”
[INFO] running gdal_translate -co NUM_THREADS=8 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 28.45% “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.tmp.tif”
Input file size is 682, 554
[INFO] running gdal_translate -co NUM_THREADS=8 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 28.45% -outsize 10% 0 “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.tmp.tif” “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.small.tif”
0
…10…
20…30…
.40.
50
60
.70
.80
90
[INFO] running gdalbuildvrt -resolution highest -r bilinear “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\merged.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.small_filled.tif” “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.tmp.tif”
[INFO] running gdal_translate -co NUM_THREADS=8 -co TILED=YES -co BIGTIFF=IF_SAFER -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 28.45% “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\merged.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\tiles.tif”
[INFO] Completed mesh_dsm.tif in 0:00:00.982271
[INFO] Sampling points from DSM: C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\mesh_dsm.tif
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\dem2points” -inputFile “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\mesh_dsm.tif” -outputFile “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\dsm_points.ply” -skirtHeightThreshold 1.5 -skirtIncrements 0.2 -skirtHeightCap 100
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\PoissonRecon” --in “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\tmp\dsm_points.ply” --out “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\odm_25dmesh.dirty.ply” --depth 11 --pointWeight 4 --samplesPerNode 1.0 --threads 7 --maxMemory 7 --bType 2 --linearFit
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\ReconstructMesh” -i “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\odm_25dmesh.dirty.ply” -o “C:\WebODM\resources\app\apps\NodeODM\data\81851fa5-b272-4a3b-8832-cd22f230c95e\odm_meshing\odm_25dmesh.ply” --remove-spikes 0 --remove-spurious 20 --smooth 0 --target-face-num 400000
Child returned 3221225477
File “C:\WebODM\resources\app\apps\ODM\stages\odm_app.py”, line 94, in execute
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 346, in run
[Previous line repeated 2 more times]
File “C:\WebODM\resources\app\apps\ODM\opendm\types.py”, line 327, in run
File “C:\WebODM\resources\app\apps\ODM\stages\odm_meshing.py”, line 66, in process
mesh.create_25dmesh(tree.filtered_point_cloud, tree.odm_25dmesh,
File “C:\WebODM\resources\app\apps\ODM\opendm\mesh.py”, line 43, in create_25dmesh
mesh = screened_poisson_reconstruction(dsm_points, outMesh, depth=depth,
File “C:\WebODM\resources\app\apps\ODM\opendm\mesh.py”, line 207, in screened_poisson_reconstruction
system.run(’"{reconstructmesh}" -i “{infile}” ’
File “C:\WebODM\resources\app\apps\ODM\opendm\system.py”, line 106, in run
opendm.system.SubprocessException: Child returned 3221225477
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See Flying Tips — OpenDroneMap 2.6.7 documentation
100 - done.
Sorry for the trouble.
Could you please confirm your WebODM version and build (they’re in white text on the blue splash screen when you first start it up).
Also, what are your computer’s specs vis-a-vis CPU and GPU?
Thanks so much for your help!
I’m on Windows 10
WebODM Version 19.1.1 build 44
CPU: Intel i7 1.9GHz 4-core
GPU: Intel UHD Graphics 620
Beautiful!
We’re on Build 45, so could you bump that up? It addresses some issues with processing under AMD GPUs, but I’m thinking the fixes might also be beneficial for Intel integrated GPUs as well.
Also, how much RAM do you have?
I’ll go ahead and try build 45 right now. I have 16 GB RAM
Same error message w/ build 45 and default settings. I can post the full error message again if that would help
Please!
I might ask you to adjust your pagefile up a lot.
I had to truncate some of the top of the error, but here is most of it:
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm create_tracks “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm”
2021-11-29 12:08:46,640 INFO: reading features
2021-11-29 12:08:50,588 DEBUG: Merging features onto tracks
2021-11-29 12:08:54,504 DEBUG: Good tracks: 88521
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm reconstruct “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm”
2021-11-29 12:09:12,396 INFO: Starting incremental reconstruction
2021-11-29 12:09:17,055 INFO: Starting reconstruction with DJI_0014.JPG and DJI_0025.JPG
2021-11-29 12:09:17,450 INFO: Two-view reconstruction inliers: 9555 / 9557
2021-11-29 12:09:19,451 INFO: Triangulated: 9556
2021-11-29 12:09:26,389 DEBUG: Ceres Solver Report: Iterations: 42, Initial cost: 4.812091e+02, Final cost: 3.026306e+01, Termination: CONVERGENCE
2021-11-29 12:09:26,665 INFO: Removed outliers: 386
2021-11-29 12:09:26,941 INFO: -------------------------------------------------------
2021-11-29 12:09:27,131 INFO: DJI_0015.JPG resection inliers: 6154 / 6155
2021-11-29 12:09:27,245 INFO: Adding DJI_0015.JPG to the reconstruction
2021-11-29 12:09:28,871 INFO: Re-triangulating
2021-11-29 12:09:28,872 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:09:31,603 DEBUG: Ceres Solver Report: Iterations: 11, Initial cost: 3.453184e+02, Final cost: 1.066628e+02, Termination: CONVERGENCE
2021-11-29 12:09:39,374 DEBUG: Ceres Solver Report: Iterations: 12, Initial cost: 1.580722e+02, Final cost: 1.098278e+02, Termination: CONVERGENCE
2021-11-29 12:09:39,856 INFO: Removed outliers: 577
2021-11-29 12:09:39,915 INFO: -------------------------------------------------------
2021-11-29 12:09:40,125 INFO: DJI_0016.JPG resection inliers: 9687 / 9690
2021-11-29 12:09:40,303 INFO: Adding DJI_0016.JPG to the reconstruction
2021-11-29 12:09:41,302 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:09:44,461 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 2.644886e+02, Final cost: 1.875509e+02, Termination: CONVERGENCE
2021-11-29 12:09:45,122 INFO: Removed outliers: 627
2021-11-29 12:09:45,189 INFO: -------------------------------------------------------
2021-11-29 12:09:45,378 INFO: DJI_0024.JPG resection inliers: 10061 / 10066
2021-11-29 12:09:45,555 INFO: Adding DJI_0024.JPG to the reconstruction
2021-11-29 12:09:46,520 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:09:50,033 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 3.187360e+02, Final cost: 2.657729e+02, Termination: CONVERGENCE
2021-11-29 12:09:50,977 INFO: Removed outliers: 701
2021-11-29 12:09:51,108 INFO: -------------------------------------------------------
2021-11-29 12:09:51,440 INFO: DJI_0026.JPG resection inliers: 10886 / 10894
2021-11-29 12:09:51,671 INFO: Adding DJI_0026.JPG to the reconstruction
2021-11-29 12:09:52,656 INFO: Re-triangulating
2021-11-29 12:09:52,657 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:09:57,267 DEBUG: Ceres Solver Report: Iterations: 7, Initial cost: 4.192643e+02, Final cost: 3.538773e+02, Termination: CONVERGENCE
2021-11-29 12:10:15,228 DEBUG: Ceres Solver Report: Iterations: 18, Initial cost: 6.611815e+02, Final cost: 3.847176e+02, Termination: CONVERGENCE
2021-11-29 12:10:16,533 INFO: Removed outliers: 1552
2021-11-29 12:10:16,638 INFO: -------------------------------------------------------
2021-11-29 12:10:16,869 INFO: DJI_0013.JPG resection inliers: 10306 / 10310
2021-11-29 12:10:17,062 INFO: Adding DJI_0013.JPG to the reconstruction
2021-11-29 12:10:18,030 INFO: -------------------------------------------------------
2021-11-29 12:10:18,248 INFO: DJI_0027.JPG resection inliers: 9997 / 10006
2021-11-29 12:10:18,433 INFO: Adding DJI_0027.JPG to the reconstruction
2021-11-29 12:10:19,156 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:10:27,106 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 6.859644e+02, Final cost: 5.333262e+02, Termination: CONVERGENCE
2021-11-29 12:10:28,415 INFO: Removed outliers: 1067
2021-11-29 12:10:28,516 INFO: -------------------------------------------------------
2021-11-29 12:10:28,686 INFO: DJI_0017.JPG resection inliers: 9005 / 9005
2021-11-29 12:10:28,844 INFO: Adding DJI_0017.JPG to the reconstruction
2021-11-29 12:10:29,458 INFO: -------------------------------------------------------
2021-11-29 12:10:29,616 INFO: DJI_0012.JPG resection inliers: 7621 / 7625
2021-11-29 12:10:29,755 INFO: Adding DJI_0012.JPG to the reconstruction
2021-11-29 12:10:30,431 INFO: -------------------------------------------------------
2021-11-29 12:10:30,561 INFO: DJI_0028.JPG resection inliers: 6827 / 6843
2021-11-29 12:10:30,686 INFO: Adding DJI_0028.JPG to the reconstruction
2021-11-29 12:10:31,342 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:10:40,661 DEBUG: Ceres Solver Report: Iterations: 9, Initial cost: 9.360132e+02, Final cost: 7.507300e+02, Termination: CONVERGENCE
2021-11-29 12:10:42,679 INFO: Removed outliers: 1551
2021-11-29 12:10:42,795 INFO: -------------------------------------------------------
2021-11-29 12:10:42,918 INFO: DJI_0011.JPG resection inliers: 5676 / 5681
2021-11-29 12:10:43,024 INFO: Adding DJI_0011.JPG to the reconstruction
2021-11-29 12:10:43,636 INFO: -------------------------------------------------------
2021-11-29 12:10:43,742 INFO: DJI_0023.JPG resection inliers: 5315 / 5318
2021-11-29 12:10:43,839 INFO: Adding DJI_0023.JPG to the reconstruction
2021-11-29 12:10:44,271 INFO: -------------------------------------------------------
2021-11-29 12:10:44,382 INFO: DJI_0029.JPG resection inliers: 5177 / 5192
2021-11-29 12:10:44,475 INFO: Adding DJI_0029.JPG to the reconstruction
2021-11-29 12:10:45,220 INFO: -------------------------------------------------------
2021-11-29 12:10:45,338 INFO: DJI_0010.JPG resection inliers: 3132 / 3149
2021-11-29 12:10:45,423 INFO: Adding DJI_0010.JPG to the reconstruction
2021-11-29 12:10:45,790 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:11:03,309 DEBUG: Ceres Solver Report: Iterations: 16, Initial cost: 1.123776e+03, Final cost: 9.444072e+02, Termination: CONVERGENCE
2021-11-29 12:11:05,271 INFO: Removed outliers: 1582
2021-11-29 12:11:05,408 INFO: -------------------------------------------------------
2021-11-29 12:11:05,467 INFO: DJI_0022.JPG resection inliers: 2890 / 2893
2021-11-29 12:11:05,516 INFO: Adding DJI_0022.JPG to the reconstruction
2021-11-29 12:11:05,965 INFO: -------------------------------------------------------
2021-11-29 12:11:06,053 INFO: DJI_0018.JPG resection inliers: 2839 / 2849
2021-11-29 12:11:06,120 INFO: Adding DJI_0018.JPG to the reconstruction
2021-11-29 12:11:06,589 INFO: -------------------------------------------------------
2021-11-29 12:11:06,629 INFO: DJI_0020.JPG resection inliers: 1792 / 1805
2021-11-29 12:11:06,668 INFO: Adding DJI_0020.JPG to the reconstruction
2021-11-29 12:11:06,798 INFO: Re-triangulating
2021-11-29 12:11:06,800 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:11:20,454 DEBUG: Ceres Solver Report: Iterations: 10, Initial cost: 1.199830e+03, Final cost: 1.034981e+03, Termination: CONVERGENCE
2021-11-29 12:12:00,296 DEBUG: Ceres Solver Report: Iterations: 16, Initial cost: 2.292553e+03, Final cost: 1.158256e+03, Termination: CONVERGENCE
2021-11-29 12:12:02,514 INFO: Removed outliers: 4083
2021-11-29 12:12:02,661 INFO: -------------------------------------------------------
2021-11-29 12:12:02,703 INFO: DJI_0019.JPG resection inliers: 1896 / 1901
2021-11-29 12:12:02,742 INFO: Adding DJI_0019.JPG to the reconstruction
2021-11-29 12:12:03,113 INFO: -------------------------------------------------------
2021-11-29 12:12:03,164 INFO: DJI_0021.JPG resection inliers: 2260 / 2263
2021-11-29 12:12:03,203 INFO: Adding DJI_0021.JPG to the reconstruction
2021-11-29 12:12:03,478 INFO: -------------------------------------------------------
2021-11-29 12:12:03,480 INFO: Shots and/or GCPs are well-conditioned. Using naive 3D-3D alignment.
2021-11-29 12:12:17,158 DEBUG: Ceres Solver Report: Iterations: 10, Initial cost: 1.244300e+03, Final cost: 1.143939e+03, Termination: CONVERGENCE
2021-11-29 12:12:19,295 INFO: Removed outliers: 874
2021-11-29 12:12:20,587 INFO: Reconstruction 0: 20 images, 87525 points
2021-11-29 12:12:20,587 INFO: 1 partial reconstructions in total.
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm compute_statistics --diagram_max_points 100000 “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm”
2021-11-29 12:12:51,996 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x00000260D8D7BDC0>
2021-11-29 12:12:51,996 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x00000260D8D7BDC0> on colorbar
2021-11-29 12:12:51,996 DEBUG: Setting pcolormesh
2021-11-29 12:12:53,462 DEBUG: locator: <matplotlib.colorbar._ColorbarAutoLocator object at 0x00000260C587DE20>
2021-11-29 12:12:53,463 DEBUG: Using auto colorbar locator <matplotlib.colorbar._ColorbarAutoLocator object at 0x00000260C587DE20> on colorbar
2021-11-29 12:12:53,464 DEBUG: Setting pcolormesh
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_geocoords --reconstruction --proj “+proj=utm +zone=16 +datum=WGS84 +units=m +no_defs +type=crs” --offset-x 709030.0 --offset-y 3781565.0 “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm”
[INFO] Updating C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm\config.yaml
[INFO] undistorted_image_max_size: 815
[INFO] Undistorting C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm …
2021-11-29 12:13:48,728 DEBUG: Undistorting image DJI_0014.JPG
2021-11-29 12:13:48,728 DEBUG: Undistorting image DJI_0025.JPG
2021-11-29 12:13:48,729 DEBUG: Undistorting image DJI_0015.JPG
2021-11-29 12:13:48,730 DEBUG: Undistorting image DJI_0016.JPG
2021-11-29 12:13:48,731 DEBUG: Undistorting image DJI_0024.JPG
2021-11-29 12:13:48,731 DEBUG: Undistorting image DJI_0026.JPG
2021-11-29 12:13:48,732 DEBUG: Undistorting image DJI_0027.JPG
2021-11-29 12:13:48,731 DEBUG: Undistorting image DJI_0013.JPG
2021-11-29 12:13:58,804 DEBUG: Undistorting image DJI_0017.JPG
2021-11-29 12:13:59,188 DEBUG: Undistorting image DJI_0012.JPG
2021-11-29 12:13:59,401 DEBUG: Undistorting image DJI_0028.JPG
2021-11-29 12:13:59,630 DEBUG: Undistorting image DJI_0011.JPG
2021-11-29 12:13:59,697 DEBUG: Undistorting image DJI_0023.JPG
2021-11-29 12:13:59,734 DEBUG: Undistorting image DJI_0029.JPG
2021-11-29 12:13:59,823 DEBUG: Undistorting image DJI_0010.JPG
2021-11-29 12:13:59,889 DEBUG: Undistorting image DJI_0022.JPG
2021-11-29 12:14:06,094 DEBUG: Undistorting image DJI_0018.JPG
2021-11-29 12:14:06,394 DEBUG: Undistorting image DJI_0020.JPG
2021-11-29 12:14:06,901 DEBUG: Undistorting image DJI_0019.JPG
2021-11-29 12:14:07,053 DEBUG: Undistorting image DJI_0021.JPG
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_visualsfm --points “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm”
[INFO] running C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\opensfm\bin\opensfm export_ply --no-cameras --point-num-views “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm”
[INFO] Filtering C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\opensfm\reconstruction.ply (statistical, meanK 16, standard deviation 2.5)
[INFO] running pdal pipeline -i “C:\Users\dcivite\AppData\Local\Temp\tmpui6q41c0.json”
[INFO] Writing ODM 2.5D Mesh file in: C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\odm_25dmesh.ply
[INFO] Created temporary directory: C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp
[INFO] running pdal info “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_filterpoints\point_cloud.ply” > “C:\Users\dcivite\AppData\Local\Temp\tmphrbv_qy6.json”
[INFO] Point cloud bounds are [minx: -25.62289619, maxx: 21.63067436] [miny: -22.1436882, maxy: 21.17457581]
[INFO] DEM resolution is (867, 946), max tile size is 4096, will split DEM generation into 1 tiles
[INFO] Generating C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\mesh_dsm_r0.14142135623730953_x0_y0.tif (max, radius: 0.14142135623730953, resolution: 0.05)
[INFO] running pdal pipeline -i “C:\Users\dcivite\AppData\Local\Temp\tmpmcr40c79.json”
[INFO] running gdalbuildvrt -input_file_list “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles_list.txt” “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.vrt”
[INFO] running gdal_translate -co NUM_THREADS=8 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 25.15% “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.tmp.tif”
Input file size is 946, 867
[INFO] running gdal_translate -co NUM_THREADS=8 -co BIGTIFF=IF_SAFER --config GDAL_CACHEMAX 25.15% -outsize 10% 0 “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.tmp.tif” “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.small.tif”
0
10…20.
30.
.40…
50
60
70
80
90
[INFO] running gdalbuildvrt -resolution highest -r bilinear “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\merged.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.small_filled.tif” “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.tmp.tif”
[INFO] running gdal_translate -co NUM_THREADS=8 -co TILED=YES -co BIGTIFF=IF_SAFER -co COMPRESS=DEFLATE --config GDAL_CACHEMAX 25.15% “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\merged.vrt” “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\tiles.tif”
[INFO] Completed mesh_dsm.tif in 0:00:01.882573
[INFO] Sampling points from DSM: C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\mesh_dsm.tif
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\dem2points” -inputFile “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\mesh_dsm.tif” -outputFile “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\dsm_points.ply” -skirtHeightThreshold 1.5 -skirtIncrements 0.2 -skirtHeightCap 100
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\PoissonRecon” --in “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\tmp\dsm_points.ply” --out “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\odm_25dmesh.dirty.ply” --depth 11 --pointWeight 4 --samplesPerNode 1.0 --threads 7 --maxMemory 6 --bType 2 --linearFit
[INFO] running “C:\WebODM\resources\app\apps\ODM\SuperBuild\install\bin\OpenMVS\ReconstructMesh” -i “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\odm_25dmesh.dirty.ply” -o “C:\WebODM\resources\app\apps\NodeODM\data\b6faee00-cec1-40fa-b54b-1654d5c66bb0\odm_meshing\odm_25dmesh.ply” --remove-spikes 0 --remove-spurious 20 --smooth 0 --target-face-num 400000
100 - done.
Thanks so much for the log!
Something is definitely amiss here on non-NVIDIA systems, I think (or at least, that’s the pattern I’m seeing) during the final meshing.
