Hello
Just got WebODM installed and configured and I’m having issues with my first project trying to create a an ortho. See screenshot below:
Any suggestions?
Hello
Any suggestions?
Welcome! In the orthophoto resolution it should be just a “2” for 2 cm not “2.0” same with dem resolution.
Mm, strange.
Can you post the “Options (JSON)” field from the “Processing Nodes – node-odm-1” menu?
Should be fixed; https://github.com/OpenDroneMap/NodeODM/pull/129 wait about an hour for the docker images to update, update WebODM, then see if it’s resolved?
Will do
