hi i am new to WebODM , and i am not that good at using command panel so i bought the software online, i followed all the steps and downloaded everything. At first i have a problem with Docker which says no container running so i tried to find a solution for that but couldnt. after that i launched the WebODM downloader everything was fine but it said i should run Docker with Linux container which i dont have. i attached a picture of what it said.
You should have the option to use Linux Containers.
See the documentation here:
If you right click the white whale icon (the docker icon) from the task tray you should have the option of switching to Linux Containers?
