Hellow,
I am new to webODM, and during the installation, I have followed all the procedures and there is no error I got so far. But the problem is after I run the command “./webodm.sh start” it has been four days now and the processing of the command hasn’t ended. is it normal or there is some things went wrong? Should I still have to wait?
image|607x500
It looks normal.The script works in foreground.
Did you try to process some data set?
Can you reach WebUI at port 8000 ?
shut it down then try again wait a few minutes then try and open webpage. are you uisng docker or docker toolbox or running natively on linux
