I just bought a new install of webodm for windows but when the install finished I selected start webodm but it failed and when I look in the e:\webodm directory there is no webodm.exe to run
If it’s the same issue as Cannot launch WebODM · Issue #1091 · OpenDroneMap/WebODM · GitHub it will be fixed in exactly 10 minutes (I’m uploading a fix right now).
Re-download the setup file and re-run it; when the program launches it should read: version 1.9.11 build 37
I got a windows security popup that that Windows Defender has blocked “Node.js: Server-side JavaScript” and prompts me if I want to install
Sorry, it went away after a minute and the finished the install and WebODM on windows id working.
Glad you’re up and running!
Please feel free to show off what you’re working on, if you’d like!
