New install on a windows 8 machine HP600 workstation with dual Xeon x5670 processors, 32gb Ram, 250gb hard drive with 75GB free space on the disc… I purchased the USB WebODM image and created a bootage USB.
Programme starts up in firefox but I immediately get a pop up crash report saying ‘Sorry the application virtualenv has stopped unexpectedly’ this goes away on its own after a while, and I am able to go into the software.
I have tried to process a data set of 100 images I took, then just 7 images and always get after around 6 seconds a ‘Process exited with code 132’
i checked the spec on the processors and they were released March 2010 so should meet the spec? Virtulisation is switched on.
In OpenODM when I look under the tabs is says system has 32gb ram and 15gb disk space… but it wont even work when I try to process 7 jpgs of around 25 megapixels.
Any ideas… when I paid for this did it mention we get support? Can I contact support or it is this forum?
Thanks for your replu. Sorry yes I have tried to process a full 200 images from a data set of crossed flight paths, 100 from one flight, 7 just to see if I got the same error… all the same… all overlapping at 84%
My computer was released march 2010… sounds like it could be too old? I managed to create the bootable USB but have no idea how to compile my own docker image? Can I do that via the bootable USB method?
Sorry just as a third update I just checked my Xeon X5670 processor specs and it says it was first released March 2010 and supports MMX, SSE 1-3 and SSSE3 so it should work?
