Need Help to Make ODM Standalone on Ubuntu 18.04
Hi all.
I’m new to OpenDroneMap, Ubuntu and python, so apologizing for ambiguous question.
I got request for make ODM to standalone, so when copy & pasted it on empty Ubuntu 18.04, then it could run without compiling.
First, I installed ODM on Ubuntu 18.04 and test run was done somehow.
Then I have to build independent library including python-pip things and I’m all at sea now.
Could someone give me any keyword can I study for this subject, then I could ask more clear again. Thank you for reading.
I’m still drifting on sea, but I learned about tarball today.
Then I could run its first line.
3
Probably I’m gonna make it someday.
Keep an eye on https://github.com/OpenDroneMap/ODM/pull/1156 which targets Ubuntu 18.04 and Python 3 (I’ve already been able to get a nominal run going, still many issues though). We’d love to get contributions on that branch.
Have you tried these instructions?
Thanks for consideration. My senior programmer said WebODM is not proper to his work. I heard it need to run on multiple Ubuntu at once.
Today I learned about site-packages.
It seems still need more trial.
I learned LD_LIBRARY_PATH and reached here.
Probably I need to learn another PATH.
I…have done somehow. I’m not sure I can share it directly. So I just leave steps I have walked.
  1. Installed ODM on Ubuntu 18.04 following this article.
    Tutorial to install OpenDroneMap (ODM) in Windows 10 — Hatari Labs
  2. Copied code folder to empty Ubuntu.
  3. Made new folder in /code and put bin things(include python), export $PATH here.
  4. Modified first line of gdal_fillnodata.py to new python path.
  5. Made another folder and put lib things, export $LD_LIBRARY_PATH here.
    This could cause few problems. I solved this with virtualenv and adding multiple path.
  6. Add some line with export on run.sh
