NDVI and RGB Orthophoto
Hello, I´m new using webODM and have a doubt about NDVI and RGB orthophotos, is it possible to proccess both RGB and NIR photos at the same time?
Or which is the best way to obtain both the RGB and NDVI orthophotos?
Thanks.
What sensor are you using? Does it export both NDVI and RGB at the same time to separate files, or are they all combined into a single multi-layer TIFF?
