Native WebODM
Hi
I have installed native WebODM, but it did not work with me. I got a message saying’’ Cannot process dataset.‘’ Is there a new version of native WebODM?
What platform are you on?
What version do you have?
WebODM for Windows Native currently should be v1.93 Build 30.
Yeah, I have version 1.9.3 Build 30
Can you share the dataset and the processing parameters?
https://drive.google.com/drive/folders/1guVpZQJqh8_PfeKT7bhzDHO9fAg8tvKl
The images and GCPs are there in the same folder. The GCPs is in UTM_10>> UTM_GCPs>> GCPs_WebODM>> AllGCPs_digitizing.txt
Parameters are
Camera : brown
Depthnap: 1500
Pc-quality : high
PC-las : true
Force gps : true
Ignore GSD : true
You have the Google Drive Folder restricted.
Try this one please.
https://drive.google.com/drive/folders/1guVpZQJqh8_PfeKT7bhzDHO9fAg8tvKl?usp=sharing
Options: cog: true, crop: 0, debug: true, dem-gapfill-steps: 4, dem-resolution: 1, dsm: true, mesh-size: 300000, min-num-features: 12000, orthophoto-cutline: true, orthophoto-resolution: 1, pc-classify: true, pc-ept: true, pc-geometric: true, pc-quality: high, use-3dmesh: true, verbose: true
How much is space on your machine? I cannot process the data. Can you please contact me via email? If yes, then I will send my email.
I used Lightning for processing your dataset as I can’t afford to have my only desktop tied up processing all day :rofl:
Here’s the final output:
meshal_alshammari-gcp-preprocessed-8523 - DroneDB
