My WebODM is very slow to process, to process 530 images in standard mode, it’s been 13hs and the bar that shows the processing is at 5%. Apparently the program didn’t recognize the VGA GTX660 and is only using the CPU, is that it? What to do?
What does your log output say?
Besides the GTX660, what are the specs of your machine?
GTX 9xx and above are needed for CUDA GPU acceleration since we rely upon newer features than supported by the CUDA runtimes on the older cards.
AMD FX 8350 eight-core 4ghz
16GB DDR4 RAM
So I need to change my VGA… It’s not worth changing just it, I have to do a total upgrade. New computer with i7 12 generation and 32Gb DDR5
Nah, not that bad. But yeah, an upgrade from that system will yield perceivable results
Yet for the subject of this post it would be helpful to have a look at your console.txt, if you are willing to share it. The hardware you use is not the fastest, but should totally be able to run an ODM node.
