My main objectivs and challenges
Hi! After presenting my self I decided to share a little bit of what I aim to do with drone/ODM. So, this post is to explore my objectives, challenges looking forward to get help and suggestions on what to study and decisions in the workflow.
As I am working on a biodiversity institute, in Argentina, my main objective is to work with environmental subject, such as:
  • Map forest remnants ( as I am working with a DJI Mavic Pro w/out much flight autonomy );
  • Use Object Detection analysis to discrete each tree crown so I can get an estimate of amount of trees;
  • Improve the Object Detection process with segmentation;
  • Estimate the biomass volume;
What I have done so far?
  • Well, I could install WODM successfully;
  • Fly around different forest remnants and process, at least one of then, the smallest remnant, in WODM with my Laptop (Intel I7, 7th generation, 16 Gb RAM). The others I couldn’t process I need to try again changing a few parameters, like the 3d process;
  • Use the orthomosaic on a Object Detection deep learning analysis, using deepforest, module to detect trees;
    As you can see, I have got an amazing result from this first attempt… I didn’t change nothing, and although the algorithm detected some trees, It also had false positives… Some close to a random results. Not completely random…
Now I need to learn and improve the use of DeepForest algorithm. Does anyone here uses it? Any suggestion on what should I try first?
Questions I have:
Is any mosaic result from ODM an Orthomosaic? Or Orthomosaic are those that the product uses RTK GPS point corrections?
I am excited with this new universe, and looking forward to learn from your experiences.
Best regards
Orthomosaics don’t really have anything to do with the type of GPS corrections, but more the fact that the images have been mosaiced together, and orthorectified, meaning perspective-corrected for changes in the terrain, camera position, and lens.
So yes, any product from ODM will be an orthophoto.
Thanks! Good to know!
