I upgraded WebODM, and tried a completely different set of mission files, same camera.
I get the error below now, I don’t think its a file corrupt issue, its not detecting it as multi camera
Launching... please wait! This can take a few minutes.
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: False
[INFO] fast_orthophoto: False
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 10
[INFO] mesh_point_weight: 4
[INFO] mesh_samples: 1.0
[INFO] mesh_size: 200000
[INFO] min_num_features: 8000
[INFO] mve_confidence: 0.6
[INFO] name: 91eca689-0dd3-4604-b144-352da328f8c6
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: False
[INFO] sm_cluster: True
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 600
[INFO] split_overlap: 150
[INFO] texturing_data_term: area
[INFO] texturing_skip_global_seam_leveling: True
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] ==============
[INFO] Running dataset stage
[INFO] Loading dataset from: /var/www/data/91eca689-0dd3-4604-b144-352da328f8c6/images
[INFO] Loading 99 images
[INFO] Wrote images database: /var/www/data/91eca689-0dd3-4604-b144-352da328f8c6/images.json
[INFO] Found 99 usable images
[ERROR] Multi-camera setup detected, but band "Rededge" (identified from "IMG_0013_5.tif") has only 19 images (instead of 20), perhaps images are missing or are corrupted. Please include all necessary files to process all bands and try again.
File "/code/run.py", line 57, in <module>
app.execute()
File "/code/stages/odm_app.py", line 92, in execute
File "/code/opendm/types.py", line 445, in run
File "/code/stages/dataset.py", line 104, in process
reconstruction = types.ODM_Reconstruction(photos)
File "/code/opendm/types.py", line 151, in __init__
self.multi_camera = self.detect_multi_camera()
File "/code/opendm/types.py", line 177, in detect_multi_camera
raise RuntimeError("Invalid multi-camera images")
RuntimeError: Invalid multi-camera images
I dumped the full set IMG_0013_1.tif … IMG_0013_5.tif and its accepted the upload now, looks like will process this time! Thanks guys.
UPDATE:
It’s been running for about 3.5 hours and completed processing all the submodels, after a while plenty of these errors started appearing …
ERROR 6: PNG driver doesn't support 7 bands. Must be 1 (grey),
2 (grey+alpha), 3 (rgb) or 4 (rgba) bands.
What could be happening here?
RESULT: Completed and looks good so far, will be analyzed further. Thanks for the help
