It can be observed the bad alignment between some bands in some spots on the map (represented by red color). The following command is the command that I use to run:
Thanks again for having developed ODM, being for me, the best open source platform for building UAV maps. However, as all platforms always need to be improved and I think I can help with this issue in concrete (in multispectral images). Currently the ODM does the multispectral mapping comparing between the different multispectral bands. I think here is the biggest flaw when trying to compare different bands in agricultural fields because it is very difficult to achieve a perfect overlay of different multispectral images. An example follows in the images below:
As shown above, you can conclude that it is really difficult to match the different images (different bands). So, in this case, my point of view was doing a full map in each band, i.e. a solo blue map, green, red, nir and rededge map (but before doing the five maps, I calibrate each image from micasense code to originate the reflectance image instead of dn image). The next two images are an example of a full map of each band (to simplify i just show two bands- green and blue):
@pierotofy I have already clean the code here
The steps to work with this project:
git clone the project
Inside odm folder write “docker-compose build”
Create a folder at Documents path called “data”
Inside data folder create another one called “1” folder
Inside “1” create another folder called “data_raw”
Inside “data_raw” folder create 2 folders “Mission” and “Panel”
Inside Mission folder put all mission images and panel images in Panel folder (tu run multispectral images)
If you don’t want to run multispectral images just put in folder “Mission” the images you want to mapping
After creating the folders and put the data just go to odm folder and type “docker-compose up”
Now just sent a get or post to start mapping: curl -XPOST localhost:5001/postjson -d '{"id":"1","is3d":true,"bands":"--rgb --ndvi --cir --ndwi --ndvi --ndre","isMultispectral":true}' -H "Content-Type: application/json" (to run Multispectral images)
