Multispectral images treated as seperate views
Hi everyone,
The datasets described in the post are available online.
  • ms2 refers to the original data
  • po refers to the data after calibration using external scripts
  • po2 are the same as the po-data the metadata was just added in 'n different way
    The WebODM “All Assets” zip files are also provided for the runs performed with either the ms2-data or po-data.
I wanted to compare the use of radiometric calibration in WebODM (using the original ms2-data) with using images (po-data) where I first calibrated the ms2-data with external scripts(received from someone else). The images were taken with a Parrot Sequoia.
My WebODM (WebODM 1.9.2 on a Windows10 system, with docker) settings were…
With WebODM calibration (ms2-data):
build-overviews: true, depthmap-resolution: 1000, ignore-gsd: true, min-num-features: 12000, optimize-disk-space: true, radiometric-calibration: camera+sun, texturing-data-term: area, texturing-skip-global-seam-leveling: true, verbose: true
With external script calibration (po-data):
build-overviews: true, depthmap-resolution: 1000, ignore-gsd: true, min-num-features: 12000, optimize-disk-space: true, texturing-data-term: area, texturing-skip-global-seam-leveling: true, verbose: true
which resulted in the following maps…
With WebODM calibration, no errors (ms2-data, success):
With external script calibration, no errors (po-data, failed):
WebODM also could not generate a plant health map for po-data.
No errors occurred during the WeODM run, or I overlooked it.
Looking at the ortho mosaics in QGIS I could see that the failed run only had one band (in addition to an alpha band). It looks like WebODM is seeing the data as 40 view instead of ten views with 4 images per view. I guessed that the problem must be somewhere in the meta data.
Before the runs I did add the meta data from the original files to the files generated with the python scripts using exiftools:
exiftool -tagsFromFile folder_with_originals/%f.tif -all:all folder_with_calibrated_files
exiftool -tagsFromFile folder_with_originals/%f.tif –xmp folder_with_calibrated_files
…to generate the po-data
I also tried
exiftool.exe -tagsFromFile multispec2/%f.TIF -xmp:all po2
…to generate the po2-data
Below is the metadata of the same equivalent example image:
original after_python_cal after_python_cal
ms2 po po2
XMP:Manufacturer Parrot Parrot Parrot
EXIF:ShutterSpeedValue 0.000184615 0.000184604 0.000184604
XMP:Model Bluegrass missing Bluegrass
EXIF:GPSDateStamp 84.1731713 84.1731713 84.1731713
EXIF:ImageDescription 550 nm 550 nm 550 nm
XMP:RigCameraIndex 0 missing missing
XMP:Pitch -17.037077 missing missing
XMP:IrradianceRelativeRotation -165,0,0 missing missing
EXIF:StripByteCounts 2457600 (Binary data 1599 bytes, use -b option to extract) (Binary data 1599 bytes, use -b option to extract)
XMP:IrradiancePitch 4.110293 missing missing
Composite:GPSDateTime 2020:09:22 11:20:54Z 2020:09:22 11:20:54Z 2020:09:22 11:20:54Z
EXIF:ExposureTime 0.000184615 0.000184604 0.000184604
XMP:IrradianceRoll 2.082358 missing missing
Composite:ShutterSpeed 0.000184615 0.000184604 0.000184604
File:FileSize 2464908 2464948 2464948
EXIF:FocalLength 3.979999908 4 4
Composite:CircleOfConfusion 0.003986137 0.004006168 0.004006168
XMP:FlightUUID 7B12007444B03EA4E6CE5F422E65900C missing missing
XMP:FisheyePolynomial 0,1,0.012748386,-0.148865228 missing missing
XMP:CentralWavelength 550 missing missing
EXIF:BitsPerSample 16 16 16
File:FileName IMG_200922_112054_0000_GRE.TIF IMG_200922_112054_0000_GRE.TIF IMG_200922_112054_0000_GRE.TIF
EXIF:MinSampleValue 0 0 0
XMP:WavelengthFWHM 40 missing missing
EXIF:DateTimeOriginal 2020:09:22 11:20:54 2020:09:22 11:20:54 2020:09:22 11:20:54
XMP:BandName Green missing missing
Composite:FOV 61.92756537 61.92756537 61.92756537
EXIF:BlackLevel 5201 5195 5192 5192 missing missing
XMP:VignettingPolynomial2DName 0,0,1,0,2,0,3,0,4,0,0,1,0,2,0,3,0,4,1,1,1,2,1,3,2,1,2,2,3,1 missing missing
EXIF:Model Sequoia Sequoia Sequoia
XMP:CaptureUUID ED0758FF42E75D9C8769152BCBFAF8F1 missing missing
EXIF:PhotometricInterpretation 1 1 1
EXIF:SubSecTimeOriginal 694177 694177 694177
EXIF:GPSLatitudeRef S S S
Composite:HyperfocalDistance 1.806305442 1.81538246 1.81538246
EXIF:GPSVersionID 2 2 0 0 2 2 0 0 2 2 0 0
Composite:ImageSize 1280x960 1280x960 1280x960
EXIF:SamplesPerPixel 1 1 1
EXIF:CameraSerialNumber PI040378AE7I006704 PI040378AE7I006704 PI040378AE7I006704
XMP:LineReadoutTime 23076 missing missing
SourceFile …/…/22Sept/flight_on_external_one_drive/multispec2/IMG_200922_112054_0000_GRE.TIF …/…/22Sept/flight_on_external_one_drive/multispec2_irrGDAL_SSensor_VIG_v2/IMG_200922_112054_0000_GRE.TIF …/…/22Sept/flight_on_external_one_drive/multispec2_irrGDAL_SSensor_VIG_v2/IMG_200922_112054_0000_GRE.TIF
EXIF:MakerNoteUnknownText 0.2 0.2 0.2
EXIF:GPSLongitude 18.8914022 18.8914022 18.8914022
EXIF:FocalLengthIn35mmFormat 30 30 30
File:FileAccessDate 2021:06:25 11:18:44+02:00 2021:06:25 12:47:38+02:00 2021:06:25 12:47:38+02:00
EXIF:StripOffsets 7308 (Binary data 2415 bytes, use -b option to extract) (Binary data 2415 bytes, use -b option to extract)
EXIF:GPSStatus A A A
EXIF:Software v1.7.1 v1.7.1 v1.7.1
XMP:FisheyeAffineSymmetric 1 missing missing
File:ExifByteOrder II II II
XMP:IrradianceCalibrationMeasurementGolden 0,600,14,1 missing missing
,1,600,345,41 0 missing missing
,2,600,5775,671 0 missing missing
,3,600,65535,16922 0 missing missing
#N/A missing missing
XMP:RigName Sequoia missing missing
File:FileType TIFF TIFF TIFF
XMP:IrradianceCalibrationMeasurement 0,600,14,1,1,600,376,40,2,600,6456,719,3,600,65535,17774 missing missing
EXIF:Make Parrot Parrot Parrot
EXIF:ImageNumber 0 0 0
XMP:FisheyeAffineMatrix 1656.667685361,0,0,1656.667685361 missing missing
ExifTool:ExifToolVersion 10.79 10.79 10.79
EXIF:GPSMapDatum WGS-84 WGS-84 WGS-84
EXIF:ExifImageWidth 1280 1280 1280
EXIF:PlanarConfiguration 1 1 1
EXIF:FNumber 2.200000078 2.2 2.2
EXIF:ExifImageHeight 960 960 960
EXIF:Orientation 3 3 3
XMP:BlackCurrent 71 missing missing
File:FilePermissions 666 666 666
XMP:ModelType fisheye missing missing
EXIF:GPSSpeedRef K K K
EXIF:FocalPlaneXResolution 266.6666559 266.6666559 266.6666559
EXIF:FocalPlaneYResolution 266.6666559 266.6666559 266.6666559
File:MIMEType image/tiff image/tiff image/tiff
Composite:GPSPosition -33.9426689996306 18.8914021998861 -33.9426689995667 18.8914021998861 -33.9426689995667 18.8914021998861
EXIF:ImageWidth 1280 1280 1280
XMP:Serial PI040438AA7K000131 missing missing
XMP:GPSZAccuracy 2.3 missing missing
Composite:Megapixels 1.2288 1.2288 1.2288
XMP:IrradianceUnitScale 1.78737134 missing missing
File:FileCreateDate 2021:06:25 11:12:48+02:00 2021:06:25 11:34:14+02:00 2021:06:25 11:34:14+02:00
XMP:SensorModel 322399.25719001074,2787.3203842349394,4893.212338771279 missing missing
Composite:GPSLatitude -33.942669 -33.942669 -33.942669
File:Directory …/…/22Sept/flight_on_external_one_drive/multispec2 …/…/22Sept/flight_on_external_one_drive/multispec2_irrGDAL_SSensor_VIG_v2 …/…/22Sept/flight_on_external_one_drive/multispec2_irrGDAL_SSensor_VIG_v2
EXIF:GPSSpeed 0.193397418 0.19339742 0.19339742
XMP:Roll 4.299296 missing missing
EXIF:ISO 100 100 100
Composite:SubSecDateTimeOriginal 2020:09:22 11:20:54.694177 2020:09:22 11:20:54.694177 2020:09:22 11:20:54.694177
XMP:IrradianceSensitivitiesGolden 282.38768,54.2517112 missing missing
EXIF:Compression 1 1 1
Composite:GPSLongitude 18.8914022 18.8914022 18.8914022
EXIF:GPSAltitudeRef 0 0 0
EXIF:GPSTimeStamp 0.472847222 0.472847222 0.472847222
EXIF:ModifyDate 2020:09:22 11:20:54 2020:09:22 11:20:54 2020:09:22 11:20:54
Composite:Aperture 2.200000078 2.2 2.2
EXIF:ExposureMode 0 0 0
Composite:FocalLength35efl 30 30 30
XMP:SensorTemperature 45.714294 missing missing
Composite:LightValue 14.67819864 14.67828542 14.67828542
EXIF:SubSecTimeDigitized 584198 584198 584198
EXIF:ApertureValue 2.200000139 2.199999997 2.199999997
XMP:IrradianceList 0 missing missing
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 #VALUE! #VALUE! #VALUE!
XMP:CalibrationPicture 0 missing missing
Composite:ScaleFactor35efl 7.537688616 7.5 7.5
EXIF:GPSAltitude 172.8990072 172.8 172.8
EXIF:SubSecTime 694177 694177 694177
XMP:PrincipalPoint 2.29307,1.794016 missing missing
EXIF:ImageHeight 960 960 960
XMP:BandGain 1 missing missing
EXIF:CreateDate 1970:01:01 00:03:10 1970:01:01 00:03:10 1970:01:01 00:03:10
File:FileModifyDate 2021:06:25 11:18:44+02:00 2021:06:25 12:47:38+02:00 2021:06:25 12:47:38+02:00
Composite:SubSecCreateDate 1970:01:01 00:03:10.584198 1970:01:01 00:03:10.584198 1970:01:01 00:03:10.584198
XMP:SunshineSerialNumber PI040379BB7I006071 missing missing
XMP:Yaw 107.605507 missing missing
EXIF:FocalPlaneResolutionUnit 4 4 4
EXIF:GPSLongitudeRef E E E
XMP:InvalidPixel 92,387,752,38,92,387 missing missing
EXIF:SpectralSensitivity 550 nm 550 nm 550 nm
EXIF:SerialNumber PI040378AE7I006704 PI040378AE7I006704 PI040378AE7I006704
File:FileTypeExtension TIF TIF TIF
EXIF:GPSLatitude 33.942669 33.942669 33.942669
EXIF:BlackLevelRepeatDim 2 2 missing missing
XMP:GPSXYAccuracy 1.345 missing missing
XMP:VignettingPolynomial2D 0.7292670791231748,0.9975321270859827,-1.8205912848289270,1.7146489942751610,-0.9065338892767812,0.4218980232048716,-0.5211784588262209,0.1670581335878976,-0.0810519371827259,-0.7773830655991261,0.7320892403987543,-0.0058065938286076,0.9104158337138633,-0.8356143597182047,-0.0278734366878383 missing missing
EXIF:ImageUniqueID 29F83C7A9CEF3F14847A74A15C60F60A 29F83C7A9CEF3F14847A74A15C60F60A 29F83C7A9CEF3F14847A74A15C60F60A
EXIF:MaxApertureValue 2.200000139 2.199999997 2.199999997
Composite:GPSAltitude 172.8990072 172.8 172.8
EXIF:OriginalRawFileName IMG_200922_112054_0000_GRE.TIF missing missing
Composite:SubSecModifyDate 2020:09:22 11:20:54.694177 2020:09:22 11:20:54.694177 2020:09:22 11:20:54.694177
XMP:CalibrationMeasurement 1,0.00584795321637427,571 missing missing
XMP:SwVersion 4.6.4 missing missing
XMP:IrradianceYaw 18.867319 missing missing
Is any of the missing metadata in the po and po2 files necessary for WebODM, for the recognition and/or treatment of multispectral data? If so, how do I add the additional metadata to my new files? I don’t know if this is where the problem is, but for example XMP:BandName is missing from my po and po2 data, but BandName does not seem to be seen by exiftools as a “standard” xmp tag.
Thanks.
