Multiple partial reconstructions
I would first thank the multiple people that have been helping me in the last few weeks with my challenging project to make orthophotos with historical images (1:40000 scale images, 152.4mm focal lens, B/W). Using ODM 2.7.0, I have had some success with the following command line:
run --project-path X:/odm_current_project/ --fast-orthophoto --geo X:/odm_current_project/code/images/geo.txt --debug --force-gps --gps-accuracy 250 --gcp X:/odm_current_project/code/images/gcp_list_count_3a6.txt --matcher-type bruteforce --feature-quality ultra --min-num-features 50000 --crop 0 --pc-tile --max-concurrency 10 --pc-quality high
Because of poor overlap and the historical nature of my images, I have been getting only partial reconstructions of my images. In this example, I get 2 partial reconstructions. For example, in the log I get the following:
2022-02-10 02:13:11,417 INFO: Reconstruction 0: 5 images, 1111 points
2022-02-10 02:13:11,417 INFO: Reconstruction 1: 4 images, 1019 points
2022-02-10 02:13:11,417 INFO: 2 partial reconstructions in total.
Based on the results, I see that the model is always based on the first set of images (Reconstruction 0). My question is the following. Can I force ODM to make both reconstruction even though it was trouble stitching both together?
Is there a switch I can use? Currently auto_boundary is set to false and -crop is at 0. What’s the best solution to this problem.
Nicolas Cadieux
My understanding is that at current, we don’t support multiple partial reconstructions, and as you noted, we pick Reconstruction 0 as the one to use for the rest of the pipeline.
I’m not aware of how to change this behavior at this time. We might need a definitive word from Stephen and/or Piero.
