I’m having the following error "Max images count exceeded.
" eror when I try to process 1373 images, my account is monthly payment and should be possible to upload 1500 images. In parallel I’m running a process with app 1100 images and would like to run another process with 1373.
Mm, strange. Are you uploading the images via the dashboard on Drone & UAV Mapping Software | WebODM? Or using a WebODM Desktop client (or via some other method)?
You should definitely be able to upload 1,500 images, so this might be some bug.
Hi good morning, right now theres is no more another task running beceause it finish yestarday. I will try again to run this process.By the way Im using webodm lightning.
I’ve looked into this and found a possible cause, which was triggered in cases where a connection is not stable and a file upload is retried multiple times; in these cases the max image count counter failed to account for the failed uploads.
I’ve made some changes to the software, when you have a moment could you try again and see if the issue persists?
I have removed the node with 180 images and I have launched the process. Now the process failed with the following error : “Connection error: HTTPSConnectionPool(host=‘spark1.webodm.net’, port=443): Max retries exceeded with url: /task/new/upload/dc989b1a-eb0f-42da-bcf8-19ada048eafe?token=db5c76f6-72f8-4b83-b0a5-168ed7efe3e8 (Caused by NewConnectionError(‘<urllib3.connection.VerifiedHTTPSConnection object at 0x000001D80E0DC3C8>: Failed to establish a new connection: [Errno 11002] Lookup timed out’))”
I’m using the auto node. I have executed a small process with 195 images. The process finished and I could download the files, but the result shown in WebODM is the following.
