How did you install ODM? (Docker, installer, natively, …)?
Singularity
singularity pull --disable-cache docker://opendronemap/odm:latest
singularity pull --disable-cache docker://opendronemap/odm:2.8.6
Using singularity 3.9.6
Currently Loaded Modulefiles:
- singularity/3.9.6(default)
What is the problem?
I was testing out using Singularity to run the container for jobs on a HPC cluster but for some reason when I try to execute a simple test job I get the error below:
[[email protected] odm_processing_code]$ singularity run --bind $images_dir:/$output_dir/code/images --writable-tmpfs odm_latest.sif --orthophoto-png --dtm --orthophoto-kmz --project-path $output_dir
[INFO] Initializing ODM ? - Tue Jul 19 04:12:41 2022
[INFO] ==============
[INFO] 3d_tiles: False
[INFO] auto_boundary: False
[INFO] auto_boundary_distance: 0
[INFO] boundary: {}
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] cog: False
[INFO] copy_to: None
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: False
[INFO] dtm: True
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_neighbors: 0
[INFO] matcher_type: flann
[INFO] max_concurrency: 36
[INFO] merge: all
[INFO] mesh_octree_depth: 11
[INFO] mesh_size: 200000
[INFO] name: code
[INFO] no_gpu: False
[INFO] orthophoto_kmz: True
[INFO] orthophoto_png: True
[INFO] pc_classify: True
[INFO] pc_copc: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_geometric: False
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] project_path: /data2/RS_GIS_Data/UAS_Data/NGEEArctic/UAS_Flights/Seward_2021/Skydio2/Kougarok/20210816/Flight_2/odm
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] rolling_shutter: False
[INFO] skip_3dmodel: False
[INFO] skip_orthophoto: False
[INFO] skip_report: False
[INFO] sky_removal: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /data2/RS_GIS_Data/UAS_Data/NGEEArctic/UAS_Flights/Seward_2021/Skydio2/Kougarok/20210816/Flight_2/odm/code/images
[INFO] Loading 187 images
[INFO] Wrote images database: /data2/RS_GIS_Data/UAS_Data/NGEEArctic/UAS_Flights/Seward_2021/Skydio2/Kougarok/20210816/Flight_2/odm/code/images.json
[INFO] Found 187 usable images
[INFO] Parsing SRS header: WGS84 UTM 3N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[INFO] Maximum photo dimensions: 4056px
[INFO] Photo dimensions for feature extraction: 2028px
[INFO] nvidia-smi not found in PATH, using CPU
[INFO] ['use_exif_size: no', 'flann_algorithm: KDTREE', 'feature_process_size: 2028', 'feature_min_frames: 10000', 'processes: 36', 'matching_gps_neighbors: 0', 'matching_gps_distance: 0', 'matching_graph_rounds: 50', 'optimize_camera_parameters: yes', 'reconstruction_algorithm: incremental', 'undistorted_image_format: tif', 'bundle_outlier_filtering_type: AUTO', 'sift_peak_threshold: 0.066', 'align_orientation_prior: vertical', 'triangulation_type: ROBUST', 'retriangulation_ratio: 2', 'matcher_type: FLANN', 'feature_type: SIFT', 'use_altitude_tag: yes', 'align_method: auto', 'local_bundle_radius: 0']
[INFO] running "/code/SuperBuild/install/bin/opensfm/bin/opensfm" detect_features "/data2/RS_GIS_Data/UAS_Data/NGEEArctic/UAS_Flights/Seward_2021/Skydio2/Kougarok/20210816/Flight_2/odm/code/opensfm"
File "/code/SuperBuild/install/bin/opensfm/bin/opensfm_main.py", line 9, in <module>
from opensfm import commands
File "/code/SuperBuild/install/bin/opensfm/opensfm/commands/__init__.py", line 1, in <module>
from . import (
File "/code/SuperBuild/install/bin/opensfm/opensfm/commands/compute_statistics.py", line 4, in <module>
from opensfm.actions import compute_statistics
File "/code/SuperBuild/install/bin/opensfm/opensfm/actions/compute_statistics.py", line 5, in <module>
from opensfm import stats
File "/code/SuperBuild/install/bin/opensfm/opensfm/stats.py", line 13, in <module>
import matplotlib as mpl
File "/home/sserbin/.local/lib/python3.9/site-packages/matplotlib/__init__.py", line 105, in <module>
from packaging.version import parse as parse_version
ModuleNotFoundError: No module named 'packaging'
Child returned 1
File "/code/opendm/types.py", line 347, in run
File "/code/opendm/types.py", line 328, in run
File "/code/stages/run_opensfm.py", line 35, in process
File "/code/opendm/osfm.py", line 410, in feature_matching
raise e
File "/code/opendm/osfm.py", line 400, in feature_matching
self.run('detect_features')
File "/code/opendm/osfm.py", line 34, in run
system.run('"%s" %s "%s"' %
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying/
I’ve even simplified more
Same error
Interestingly the same source containers mostly work in podman but fail for another reason late in the processing, but I dont yet know why that is. I think perhaps an issue with trying to create the DTM. The example above does seem to generally work with podman/docker.
Not really sure why in Singularity it would be telling me a package is missing.
What should be the expected behavior? If this is a feature request, please describe in detail the changes you think should be made to the code, citing files and lines where changes should be made, if possible.
I would expect the job to execute and generate an orthophoto.
How can we reproduce this? What steps did you do to trigger the problem? If this is an issue with processing a dataset, YOU MUST include a copy of your dataset uploaded on Google Drive or Dropbox (otherwise we cannot reproduce this).
images_dir=/data2/RS_GIS_Data/UAS_Data/NGEEArctic/UAS_Flights/Seward_2021/Skydio2/Kougarok/20210816/Flight_2/images
name=`basename $images_dir`
output_dir=/data2/RS_GIS_Data/UAS_Data/NGEEArctic/UAS_Flights/Seward_2021/Skydio2/Kougarok/20210816/Flight_2/odm
mkdir -p $output_dir
singularity run --bind $images_dir:/$output_dir/code/images \
--writable-tmpfs odm_latest.sif \
--orthophoto-png --dtm --orthophoto-kmz --feature-quality ultra --max-concurrency 16 \
--use-hybrid-bundle-adjustment --build-overviews --min-num-features 10000 \
I suspect I may not be invoking the run correctly. Any insight would be much appreciated. Thanks!
I use/create a lot of containerized environments that run in Docker and Singularity but I seem to not really understand how the code expects to be provided the location of the source image files and output(s). I think its also trying to create or point to the code folder which might be where its looking for the python code. Perhaps I just need a little more help on how to structure my folders and the singularity run command to find the folders and have the data in the expected location(s)
