I’ve looked around and did not find something thay answer my question…
So, i’m used to fly some quite large areas, with some hills. No terrain following, high altitude.
After processing as usual, i had few maps that did not come full as usual
I tried another settings after some reseach here and Github but it seems to not show much of improvement…
So here comes the details :
Map is mostly forest
65% side overlap
75% front overlap
processed with thoses option (for the screenshot down bellow) :
crop: 0, dem-gapfill-steps: 10, dsm: true, matcher-distance: 0, min-num-features: 24000
Those sidelap/overlap can be a bit low for homogenous scenes… Subsequent flights might be better served by at least increasing overlap (if your camera/storage can handle the reduced photo interval).
Are you able to share the dataset? I think increasing feature-quality may help a bit.
i’m not sure i’m able to share the full data, at my local scale i’ts kinda buisness secret (for the whole world it’s a joke hahaha)
I’ll try raising feature quality and overlap of next flights.
Try --feature-quality ultra and --feature-type HAHOG. Forest areas are tricky to process. Also make sure you are NOT resizing your images with WebODM when uploading the images.
