I havent seen a posting regarding this issue. So I’ll ask. I have a data set. I’m trying to use GCP’s to correct it. I create the GCP file using WebODM control point inter face. I process and get this message in the georeference log file.
“Missing input in order to use GCP for georeferencing. Using EXIF data instead”.
Can any of you point me in the right direction to correctly geo reference my project? Is it the control configuration? File formatting?
Below is the entire georeference log file:
code/build/bin/odm_georef_log.txt
Arguments given
-bundleFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/opensfm/bundle_r000.out
-inputTransformFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/opensfm/geocoords_transformation.txt
-inputCoordFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/coords.txt
-inputFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_texturing/odm_textured_model.obj
-outputFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_texturing/odm_textured_model_geo.obj
-logFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_log.txt
-outputTransformFile
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_transform.txt
-georefFileOutputPath
/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_model_geo.txt
Reading cameras from: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/opensfm/bundle_r000.out
Reading transform file from:
Reading cameras gps exif positions from: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/coords.txt
Reading textured mesh from: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_texturing/odm_textured_model.obj
Writing output to: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_texturing/odm_textured_model_geo.obj
Log file path was set to: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_log.txt
Transform file path was set to: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_transform.txt
Georef file output path is set to: /var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_model_geo.txt
Missing input in order to use GCP for georeferencing. Using EXIF data instead.
Reading mesh file…
… mesh file read.
Applying transform to mesh…
… mesh transformed.
Successfully saved model.
Saving final transform file to ‘/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_transform.txt’…
… final transform saved.
Saving georeference system file to ‘/var/www/data/204b15c7-7bf4-4902-884c-118d2d3630f0/odm_georeferencing/odm_georeferencing_model_geo.txt’…
… georeference system saved.
Mike
