Missing data on 2d and 3d map
I am having problems with a recent data set. The task is completing successfully but a portion of the map/model is left blank. As you can see in the picture there are camera markers for all of the pictures but no data in the last quarter or so of the map/model. This model was created with the volume analysis preset but the same results happened with other presets. Any help is much appreciated. Thanks.
Try increasing --min-num-features. Sometimes if not enough features are recognized, the model will be incomplete.
I will do that. Any recommendation on a number to try?
Thanks,
Start by doubling the default.
That did it. Thank you guys.
