From @Ntweat on Thu Sep 28 2017 20:49:02 GMT+0000 (UTC)
Hi
I built opendrone with ORB SLAM, but the checkerboad link is not working.
Where else can I find it?
Copied from original issue: https://github.com/OpenDroneMap/OpenDroneMap/issues/678
From @pierotofy on Thu Sep 28 2017 21:35:15 GMT+0000 (UTC)
Does this work? http://docs.opencv.org/2.4/_downloads/pattern.png
Could you also point out where the broken link is exactly?
From @Ntweat on Thu Sep 28 2017 21:38:13 GMT+0000 (UTC)
@pierotofy Thanks
Links are broken on https://github.com/OpenDroneMap/OpenDroneMap/wiki/Reconstruction-from-Video
All the dropbox links are broken
From @pierotofy on Thu Sep 28 2017 21:40:25 GMT+0000 (UTC)
Mm, @smathermather are you dropbox user 2801164
From @smathermather on Fri Sep 29 2017 02:31:54 GMT+0000 (UTC)
Noap. But I bet @paulinus is.
From @Ntweat on Mon Oct 02 2017 15:36:49 GMT+0000 (UTC)
@pierotofy @smathermather can you give me the config.yaml and the castle video files?
I tried running opendrone sfm on my video it is not able to track the camera or features.
