MicMac processing node doesn't produce point cloud
I’m running node-micmac on my main processing PC in docker under UNIX (docker run -p 3000:3000 dronemapper/node-micmac) connected to a laptop that I keep WebODM running on so that myself and others can access previous projects. It’s working perfectly, except for the fact that I’m not getting the ‘3D’ output as I would with the node-odm version. The (excellent) orthomosaics are generated, but if I switch to 3D… nothing. The last couple of lines of Log (before the ‘compressing’ line) seem to point to an issue, but I’m very much in the dark. They are:
"ERROR 6: zoom_level > 22 not supported
Point cloud tiles will not be generated
Postprocessing: done (•̀ᴗ•́)و!"
Any idea which direction I should start looking in?
Full consle output ?
Thank you for pointing me at that. I’ll take a dig through. Here’s that log file:
