I am pasting the log into the reply. Let me know if this is not the preferred method …
The entire log was longer than the character limit so I took the liberty of removing blocks of similar text. These points are denoted as
NodeMICMAC by DroneMapper.com
[DEBUG] Trying CDLL(libc.so.6)
[DEBUG] Library path: ‘libc.so.6’
[DEBUG] DLL: <CDLL ‘libc.so.6’, handle 7f2a3d0de000 at 7f2a3d0557d0>
[INFO] Initializing NodeMICMAC app - Fri Apr 24 07:46:43 2020
[INFO] Namespace(camera_cloud=False, ccd_height=None, ccd_width=None, gcp=None, image_footprint=False, images=None, matcher_distance=None, max_concurrency=4, multi_scale=False, name=‘3c98a808-f0ca-4bc4-9f41-4edf090eaf72’, project_path=‘/var/www/data’, remove_ortho_tiles=False, resize_to=800, zoom=4)
[INFO] Starting…
[DEBUG] running exiftool -filename -gpslongitude -gpslatitude -gpsaltitude -T -n .jpg > imageEXIF.txt
[INFO] UTM - 14
[INFO] Hemisphere - north
[INFO] jpg
[INFO] {‘utm_zone’: 14, ‘hemisphere’: ‘north’}
“.*.jpg”: 213 matches.
ND_X3_lens_test-10.jpg : WGS84(rad) [-1.68459,0.773033,562.6] GeoC [-519278,-4.54374e+06,4.43173e+06]
ND_X3_lens_test-100.jpg : WGS84(rad) [-1.68461,0.773037,562.8] GeoC [-519371,-4.54371e+06,4.43175e+06]
ND_X3_lens_test-101.jpg : WGS84(rad) [-1.68461,0.77304,562.7] GeoC [-519368,-4.5437e+06,4.43176e+06]
ND_X3_lens_test-102.jpg : WGS84(rad) [-1.68461,0.773041,562.3] GeoC [-519366,-4.54369e+06,4.43177e+06]
ND_X3_lens_test-103.jpg : WGS84(rad) [-1.68461,0.773044,562.4] GeoC [-519367,-4.54368e+06,4.43178e+06]
ND_X3_lens_test-104.jpg : WGS84(rad) [-1.68461,0.773046,562.6] GeoC [-519366,-4.54367e+06,4.43179e+06]
ND_X3_lens_test-105.jpg : WGS84(rad) [-1.68461,0.773048,562.7] GeoC [-519365,-4.54366e+06,4.4318e+06]
ND_X3_lens_test-106.jpg : WGS84(rad) [-1.68461,0.77305,562.8] GeoC [-519363,-4.54366e+06,4.43181e+06]
ND_X3_lens_test-107.jpg : WGS84(rad) [-1.68461,0.773052,562.6] GeoC [-519363,-4.54365e+06,4.43181e+06]
ND_X3_lens_test-108.jpg : WGS84(rad) [-1.68461,0.773054,561.7] GeoC [-519362,-4.54364e+06,4.43183e+06]
ND_X3_lens_test-109.jpg : WGS84(rad) [-1.68461,0.773057,562.4] GeoC [-519360,-4.54362e+06,4.43184e+06]
ND_X3_lens_test-11.jpg : WGS84(rad) [-1.68459,0.773036,562.6] GeoC [-519277,-4.54373e+06,4.43174e+06]
ND_X3_lens_test-110.jpg : WGS84(rad) [-1.68461,0.77306,562.8] GeoC [-519359,-4.54361e+06,4.43185e+06]
ND_X3_lens_test-111.jpg : WGS84(rad) [-1.68461,0.773062,562.7] GeoC [-519358,-4.5436e+06,4.43186e+06]
ND_X3_lens_test-86.jpg : WGS84(rad) [-1.68461,0.773,563.1] GeoC [-519390,-4.54387e+06,4.43158e+06]
ND_X3_lens_test-87.jpg : WGS84(rad) [-1.68461,0.773003,562.9] GeoC [-519388,-4.54386e+06,4.43159e+06]
ND_X3_lens
_test-88.jpg : WGS84(rad) [-1.68461,0.773006,563] GeoC [-519387,-4.54385e+06,4.4316e+06]
ND_X3_lens_test-89.jpg : WGS84(rad) [-1.68461,0.773009,562.8] GeoC [-519386,-4.54384e+06,4.43162e+06]
ND_X3_lens_test-9.jpg : WGS84(rad) [-1.68459,0.773032,562.8] GeoC [-519279,-4.54375e+06,4.43173e+06]
ND_X3_lens_test-90.jpg : WGS84(rad) [-1.68461,0.773012,561.9] GeoC [-519384,-4.54382e+06,4.43163e+06]
ND_X3_lens_test-91.jpg : WGS84(rad) [-1.68461,0.773015,562.8] GeoC [-519382,-4.54381e+06,4.43165e+06]
ND_X3_lens_test-92.jpg : WGS84(rad) [-1.68461,0.773018,563.4] GeoC [-519380,-4.5438e+06,4.43166e+06]
ND_X3_lens_test-93.jpg : WGS84(rad) [-1.68461,0.77302,563.4] GeoC [-519379,-4.54379e+06,4.43167e+06]
ND_X3_lens_test-94.jpg : WGS84(rad) [-1.68461,0.773022,563.2] GeoC [-519378,-4.54378e+06,4.43168e+06]
ND_X3_lens_test-95.jpg : WGS84(rad) [-1.68461,0.773025,562.9] GeoC [-519378,-4.54377e+06,4.43169e+06]
ND_X3_lens_test-96.jpg : WGS84(rad) [-1.68461,0.773028,563.2] GeoC [-519376,-4.54375e+06,4.43171e+06]
ND_X3_lens_test-97.jpg : WGS84(rad) [-1.68461,0.773031,562.5] GeoC [-519374,-4.54374e+06,4.43172e+06]
ND_X3_lens_test-98.jpg : WGS84(rad) [-1.68461,0.773033,562.5] GeoC [-519372,-4.54373e+06,4.43173e+06]
ND_X3_lens_test-99.jpg : WGS84(rad) [-1.68461,0.773035,562.7] GeoC [-519372,-4.54372e+06,4.43174e+06]
ND_X3_lens_test.jpg : WGS84(rad) [-1.68469,0.77303,471.3] GeoC [-519756,-4.54363e+06,4.43165e+06]
[INFO] Image pairs by auto-distance
[DEBUG] running mm3d OriConvert “#F=N X Y Z” GpsCoordinatesFromExif.txt RAWGNSS_N ChSys=Deg[email protected] MTD1=1 NameCple=dronemapperPair.xml DN=
Comment=[#]
Format=[N X Y Z]
Read data for ND_X3_lens_test-10.jpg NB=0 T=0
Read data for ND_X3_lens_test-100.jpg NB=1 T=1
[-95.1448,26.2252,0.200792]
Read data for ND_X3_lens_test-101.jpg NB=2 T=2
[1.75598,13.891,-0.100133]
Read data for ND_X3_lens_test-102.jpg NB=3 T=3
[0.478882,11.1128,-0.400126]
Read data for ND_X3_lens_test-103.jpg NB=4 T=4
[-1.9955,13.891,0.099823]
Read data for ND_X3_lens_test-104.jpg NB=5 T=5
[-0.239492,15.1134,0.199768]
Read data for ND_X3_lens_test-105.jpg NB=6 T=6
[0.638515,13.002,0.0997692]
Read data for ND_X3_lens_test-106.jpg NB=7 T=7
[0.239426,11.4462,0.0997757]
Read data for ND_X3_lens_test-107.jpg NB=8 T=8
[-0.239488,13.0019,-0.200278]
Read data for ND_X3_lens_test-96.jpg NB=208 T=208
[-4.62311e-05,20.1141,0.300053]
Read data for ND_X3_lens_test-97.jpg NB=209 T=209
[0.877976,16.3358,-0.700006]
Read data for ND_X3_lens_test-98.jpg NB=210 T=210
[0.399065,13.2242,-3.44496e-05]
Read data for ND_X3_lens_test-99.jpg NB=211 T=211
[-0.39913,13.5576,0.199938]
Read data for ND_X3_lens_test.jpg NB=212 T=212
[-391.59,-32.3275,-91.4109]
PATC =
** MicMac: a free open source project for photogrammetry **
** hosted at Ecole Nationale des Sciences Geographiques **
** in Marne-la-Vallee, for IGN-France **
** The project is funded by : **
** - Institut National de l’Information Geographique et Forestiere **
** (IGN main funder since 2003) **
** - the french FUI Project “Culture 3D Cloud” (and MAP-CNRS) **
** - the french ANR Project “MONUMENTUM”(collaborating with MAP-CNRS)**
** Research also currently supported by : **
** - CNES (French Space Agency) - via TOSCA Committee (and IPGP) **
** - Compagnie Nationale du Rhone **
** - Vinci-Construction-Terrassement **
** - ERC Advanced Grant A.Kaeaeb “ICEMASS” (University of Oslo) **
** Current Team: MP Deseilligny, D Jouin, J Belvaux, G Maillet, **
** L Girod, E Rupnik, JM Muller, M Daakir, TG Nguyen **
** Contact for participating : [email protected] **
** Hope you enjoy, todo list in case of any problem using MicMac : **
** (0) Take a Pastis **
** (1) Switch your computer off and on again **
** (2) Install it on Gnu-Linux (work better on) **
** (3) See the wiki at http://micmac.ensg.eu/ **
** (4) Contact the forum http://forum-micmac.forumprod.com/ **
[DEBUG] running mm3d Tapioca File dronemapperPair.xml 800 ByP=4
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-10.jpg ./Tmp-MM-Dir/ND_X3_lens_test-10.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-100.jpg ./Tmp-MM-Dir/ND_X3_lens_test-100.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-101.jpg ./Tmp-MM-Dir/ND_X3_lens_test-101.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-102.jpg ./Tmp-MM-Dir/ND_X3_lens_test-102.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-103.jpg ./Tmp-MM-Dir/ND_X3_lens_test-103.jpg-MDT-4227.xml
mlXif ./ND_X3_lens_test-38.jpg ./Tmp-MM-Dir/ND_X3_lens_test-38.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-39.jpg ./Tmp-MM-Dir/ND_X3_lens_test-39.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-4.jpg ./Tmp-MM-Dir/ND_X3_lens_test-4.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-40.jpg ./Tmp-MM-Dir/ND_X3_lens_test-40.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-41.jpg ./Tmp-MM-Dir/ND_X3_lens_test-41.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-42.jpg ./Tmp-MM-Dir/ND_X3_lens_test-42.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-43.jpg ./Tmp-MM-Dir/ND_X3_lens_test-43.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-44.jpg ./Tmp-MM-Dir/ND_X3_lens_test-44.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-45.jpg ./Tmp-MM-Dir/ND_X3_lens_test-45.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-46.jpg ./Tmp-MM-Dir/ND_X3_lens_test-46.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-47.jpg ./Tmp-MM-Dir/ND_X3_lens_test-47.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-48.jpg ./Tmp-MM-Dir/ND_X3_lens_test-48.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-49.jpg ./Tmp-MM-Dir/ND_X3_lens_test-49.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-5.jpg ./Tmp-MM-Dir/ND_X3_lens_test-5.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-50.jpg ./Tmp-MM-Dir/ND_X3_lens_test-50.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-51.jpg ./Tmp-MM-Dir/ND_X3_lens_test-51.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-52.jpg ./Tmp-MM-Dir/ND_X3_lens_test-52.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-53.jpg ./Tmp-MM-Dir/ND_X3_lens_test-53.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-54.jpg ./Tmp-MM-Dir/ND_X3_lens_test-54.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-55.jpg ./Tmp-MM-Dir/ND_X3_lens_test-55.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-56.jpg ./Tmp-MM-Dir/ND_X3_lens_test-56.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-57.jpg ./Tmp-MM-Dir/ND_X3_lens_test-57.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-58.jpg ./Tmp-MM-Dir/ND_X3_lens_test-58.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-59.jpg ./Tmp-MM-Dir/ND_X3_lens_test-59.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-6.jpg ./Tmp-MM-Dir/ND_X3_lens_test-6.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-60.jpg ./Tmp-MM-Dir/ND_X3_lens_test-60.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-61.jpg ./Tmp-MM-Dir/ND_X3_lens_test-61.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-62.jpg ./Tmp-MM-Dir/ND_X3_lens_test-62.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-63.jpg ./Tmp-MM-Dir/ND_X3_lens_test-63.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-64.jpg ./Tmp-MM-Dir/ND_X3_lens_test-64.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-65.jpg ./Tmp-MM-Dir/ND_X3_lens_test-65.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-66.jpg ./Tmp-MM-Dir/ND_X3_lens_test-66.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-67.jpg ./Tmp-MM-Dir/ND_X3_lens_test-67.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-68.jpg ./Tmp-MM-Dir/ND_X3_lens_test-68.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-69.jpg ./Tmp-MM-Dir/ND_X3_lens_test-69.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-7.jpg ./Tmp-MM-Dir/ND_X3_lens_test-7.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-70.jpg ./Tmp-MM-Dir/ND_X3_lens_test-70.jpg-MDT-4
227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-71.jpg ./Tmp-MM-Dir/ND_X3_lens_test-71.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-72.jpg ./Tmp-MM-Dir/ND_X3_lens_test-72.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-73.jpg ./Tmp-MM-Dir/ND_X3_lens_test-73.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-74.jpg ./Tmp-MM-Dir/ND_X3_lens_test-74.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-75.jpg ./Tmp-MM-Dir/ND_X3_lens_test-75.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-76.jpg ./Tmp-MM-Dir/ND_X3_lens_test-76.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-77.jpg ./Tmp-MM-Dir/ND_X3_lens_test-77.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-78.jpg ./Tmp-MM-Dir/ND_X3_lens_test-78.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-79.jpg ./Tmp-MM-Dir/ND_X3_lens_test-79.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-8.jpg ./Tmp-MM-Dir/ND_X3_lens_test-8.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-80.jpg ./Tmp-MM-Dir/ND_X3_lens_test-80.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-81.jpg ./Tmp-MM-Dir/ND_X3_lens_test-81.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-82.jpg ./Tmp-MM-Dir/ND_X3_lens_test-82.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-83.jpg ./Tmp-MM-Dir/ND_X3_lens_test-83.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-84.jpg ./Tmp-MM-Dir/ND_X3_lens_test-84.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-85.jpg ./Tmp-MM-Dir/ND_X3_lens_test-85.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-86.jpg ./Tmp-MM-Dir/ND_X3_lens_test-86.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-87.jpg ./Tmp-MM-Dir/ND_X3_lens_test-87.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-88.jpg ./Tmp-MM-Dir/ND_X3_lens_test-88.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-89.jpg ./Tmp-MM-Dir/ND_X3_lens_test-89.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-9.jpg ./Tmp-MM-Dir/ND_X3_lens_test-9.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-90.jpg ./Tmp-MM-Dir/ND_X3_lens_test-90.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-91.jpg ./Tmp-MM-Dir/ND_X3_lens_test-91.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-92.jpg ./Tmp-MM-Dir/ND_X3_lens_test-92.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-93.jpg ./Tmp-MM-Dir/ND_X3_lens_test-93.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-94.jpg ./Tmp-MM-Dir/ND_X3_lens_test-94.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-95.jpg ./Tmp-MM-Dir/ND_X3_lens_test-95.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-96.jpg ./Tmp-MM-Dir/ND_X3_lens_test-96.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-97.jpg ./Tmp-MM-Dir/ND_X3_lens_test-97.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-98.jpg ./Tmp-MM-Dir/ND_X3_lens_test-98.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test-99.jpg ./Tmp-MM-Dir/ND_X3_lens_test-99.jpg-MDT-4227.xml
/code/micmac/bin/mm3d TestLib XmlXif ./ND_X3_lens_test.jpg ./Tmp-MM-Dir/ND_X3_lens_test.jpg-MDT-4227.xml
— using detecting tool : [mm3d:Sift]
— using matching tool : [mm3d:Ann]
P-rogramme utilisant, *
A-utopano *
S-ift pour les *
T-ie-points dans les *
I-mage *
S *
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-10.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-10.tif.dat
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-100.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-100.tif.dat
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-101.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-101.tif.dat
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-102.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-102.tif.dat
6537 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-103.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-103.tif.dat
6821 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-104.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-104.tif.dat
7053 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-11.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-11.tif.dat
9195 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-12.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-12.tif.dat
5403 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-4.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-4.tif.dat
6044 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-53.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-53.tif.dat
9375 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-54.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-54.tif.dat
8851 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-7.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-7.tif.dat
7227 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-8.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-8.tif.dat
7655 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-9.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-9.tif.dat
7433 sift points
/code/micmac/bin/mm3d Sift ./Pastis/Resol31_Teta0_ND_X3_lens_test-99.tif -o ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-99.tif.dat
9645 sift points
/code/micmac/bin/mm3d Ann ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-100.tif.dat ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-10.tif.dat ./Pastis/LBPp-Match-LBPpResol31_Teta0_ND_X3_lens_test-100.tif/LBPpResol31_Teta0_ND_X3_lens_test-10.tif.result -ratio 0.600000
./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-100.tif.dat : 7053 points ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-10.tif.dat : 9195 points => 1198 matches
/code/micmac/bin/mm3d Ann ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-100.tif.dat ./Pastis/LBPpResol31_Teta0_ND_X3_lens_test-101.tif.dat ./Pastis/LBPp-Match-LBPpResol31_Teta0_ND_X3_lens_test-100.tif/LBPpResol31_Teta0_ND_X3_lens_test-101.tif.result -ratio 0.600000
9048 sift points
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-121.jpg ND_X3_lens_test-127.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-118.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 3052IN 3052 OUT 0
Apres Rm Dup, 2197
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-119.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 2436IN 2436 OUT 0
Apres Rm Dup, 1785
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-12.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 1854IN 1854 OUT 0
Apres Rm Dup, 1331
Cple Init = 3213IN 3213 OUT 0
Apres Rm Dup, 2298
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-120.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-121.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 3IN 3 OUT 0
Apres Rm Dup, 1
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-123.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 3742IN 3742 OUT 0
Apres Rm Dup, 2627
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-124.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 4557IN 4557 OUT 0
Apres Rm Dup, 3190
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-122.jpg ND_X3_lens_test-125.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 4852IN 4852 OUT 0
Apres Rm Dup, 3357
/code/micmac/bin/m
Cple Init = 3788IN 3788 OUT 0
Apres Rm Dup, 2475
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-30.jpg ND_X3_lens_test-34.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 3946IN 3946 OUT 0
Apres Rm Dup, 2658
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-4.jpg ND_X3_lens_test-5.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 7IN 7 OUT 0
Apres Rm Dup, 2
/code/micmac/bin/mm3d pastis ./ ND_X3_lens_test-5.jpg ND_X3_lens_test-6.jpg 800 MkF=./MkTapioca NbMinPtsExp=2 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat IsRelancedByThis=1 OnlyXML=1
Cple Init = 6IN 6 OUT 0
Apres Rm Dup, 1
Cple Init = 3925IN 3925 OUT 0
Apres Rm Dup, 2614
Cple Init = 4022IN 4022 OUT 0
Apres Rm Dup, 2755
Cple Init = 5531IN 5531 OUT 0
Apres Rm Dup, 3796
“/code/micmac/bin/mm3d” Pastis ./ “[email protected]” 800 “MkF=./MkTapioca” NbMinPtsExp=2 ForceByDico=1 Detect=mm3d:Sift Match=mm3d:Ann ratio=0.600000 NKS=NKS-Assoc-CplIm2Hom@@dat
[DEBUG] running mm3d Tapas RadialStd ..jpg EcMax=500
"..jpg": 213 matches.
BEGIN Pre-compile
“NKS-Set-OfPatternAndFoc@[[..jpg]]@[email protected]": 213 matches.
MdPppppF= 1444.53 SFE=-1 FocMm3.6 F35=20 XSZ=[2500,1875]
NEW CALIB TheKeyCalib__Foc-3600_Cam-FC350
"NKS-Set-OfPatternAndFoc@[[..jpg]]@[email protected]”: 213 matches.
BEGIN Load Observation
“NKS-Set-Homol@@dat”: 3338 matches.
NB PACK PTS 3338
“[email protected]#@LL?~~XXXXXXXXXX”: 0 matches.
Pack Obs [email protected]#@LL?~~XXXXXXXXXX NB 0
BEGIN Init Inconnues
NO GUIMBAL ND_X3_lens_test-81.jpg 1
MST 212
ND_X3_lens_test-80.jpg[1] ; Pere : ND_X3_lens_test-81.jpg
ND_X3_lens_test-82.jpg[2] ; Pere : ND_X3_lens_test-81.jpg ; Mere : ND_X3_lens_test-80.jpg
ND_X3_lens_test-71.jpg[2] ; Pere : ND_X3_lens_test-80.jpg ; Mere : ND_X3_lens_test-81.jpg
ND_X3_lens_test-90.jpg[17] ; Pere : ND_X3_lens_test-89.jpg ; Mere : ND_X3_lens_test-148.jpg
ND_X3_lens_test-91.jpg[36] ; Pere : ND_X3_lens_test-92.jpg ; Mere : ND_X3_lens_test-90.jpg
BEST CAM TESTED ND_X3_lens_test.jpg NB Annc 0
UN-Connected : ND_X3_lens_test-2.jpg
UN-Connected : ND_X3_lens_test-3.jpg
UN-Connected : ND_X3_lens_test.jpg
| Sorry, the following FATAL ERROR happened
| Connection pb in MST
| (Elise’s) LOCATION :
| Error was detected
| at line : 242
of file : /var/www/micmac/src/uti_phgrm/Apero/GraphePose.cpp |
Bye (press enter) |
Com = “/code/micmac/bin/mm3d” Apero “/code/micmac/include/XML_MicMac/Apero-Glob-New.xml” DirectoryChantier=./ “+PatternAllIm=..jpg" "+SetIm=NKS-Set-OfPatternAndFoc@[[..jpg]]@[email protected]” +AeroOut=-RadialStd +Ext=dat +ModeleCam=eCalibAutomRadial DoCompensation=1 +SeuilFE=-1.000000 +TetaLVM=0.100000 +CentreLVM=1.000000 +IntrLVM=0.100000 +RayFEInit=0.850000 +CalibIn=-#@LL?~~XXXXXXXXXX +AeroIn=-#@LL?~~XXXXXXXXXX +VitesseInit=4 +PropDiagU=1.000000 +DegRadMax=3 +LibFoc=1 +LibPP=1 +LibCD=1 +DegGen=0 +LibDec=0 +Fast=0 +UsePano=true +CondMaxPano=1000000.000000 +EcartMaxFin=500.000000 +DSElimB=1 +DSElimB=1 |
FAIL IN : |
[ERROR] Child returned 255 |
[DEBUG] running mm3d CenterBascule .*.jpg RadialStd RAWGNSS_N Ground_Init_RTL |
############## For Value RadialStd ############ |
| Ori name is not a valid existing directory
| Error was detected
| at line : 4081
of file : /var/www/micmac/src/photogram/ChantierNameAssoc.cpp |
Bye (press enter) |
[ERROR] Child returned 1 |
[DEBUG] running mm3d Campari .*.jpg Ground_Init_RTL Ground_RTL EmGPS=[RAWGNSS_N,5] AllFree=0 |
############## For Value Ground_Init_RTL ############ |
| Error was detected
| at line : 4081
Bye (press enter) |
[DEBUG] running mm3d ChgSysCo .*.jpg Ground_RTL [email protected] Ground_UTM |
############## For Value Ground_RTL ############ |
| Error was detected
| at line : 4081
Bye (press enter) |
[DEBUG] running mm3d Malt Ortho .*.jpg Ground_UTM EZA=1 ZoomI=64 ZoomF=4 NbVI=2 HrOr=1 RoundResol=0 ResolOrtho=1 DefCor=0.0005 NbProc=4 |
############## For Value Ground_UTM ############ |
| Error was detected
| at line : 4081
Bye (press enter) |
[ERROR] [Errno 2] No such file or directory: ‘Ortho-MEC-Malt/Param-Tawny.xml’ |
Postprocessing: /var/www/data/3c98a808-f0ca-4bc4-9f41-4edf090eaf72 |
No orthophoto found at odm_orthophoto/odm_orthophoto.tif: will skip tiling
No orthophoto found at odm_orthophoto/odm_orthophoto.tif: will skip MBTiles generation
Point cloud tiles will not be generated
Compressing all.zip
Done!
