[DEBUG] running mm3d Tapas RadialStd ..JPG EcMax=500
"..JPG": 69 matches.
BEGIN Pre-compile
“[email protected][[..JPG]]@0.000000@100000.000000": 69 matches.
MdPppppF= 2121.45 SFE=-1 FocMm3.6 F35=20 XSZ=[4000,2250]
NEW CALIB TheKeyCalib__Foc-3600_Cam-FC300C
"[email protected][[..JPG]]@0.000000@100000.000000”: 69 matches.
BEGIN Load Observation
“[email protected]@dat”: 692 matches.
FOR Pt [1577.73,2498.69] Box = [-76.4898,-76.4898][4076.49,2326.49]| Sorry, the following FATAL ERROR happened
| POINT HOM OUT OF IMAGE
| (Elise’s) LOCATION :
| Error was detected
| at line : 854
of file : /var/www/micmac/src/uti_phgrm/Apero/cPackMultipleLiaison.cpp Bye (press enter)
Just installed the update and I’m running MicMac tests. If I test it on a dataset that is flow top-down only it works, but if I throw in photos of POI, it fails with this error on every dataset so far.
Anyone know what is wrong?
This ran fine on the native Node, but works fine when I only use top down photos of the same set.
