Hello, I have been successfully processing individual band micasense multispectral imagery, and have been wanting to try processing already aligned stack images. I’m hoping that this might cut down on processing times or achieve a better alignment. However, I have never been able to use my stack images and am curious what is wrong about them. I’m including a link to a google drive folder containing 5 stack images which I’ve tried to copy the correct exif and xmp data to, along with the full log from running them.
This issue has persisted through every version of odm that I have tried it with, and I’m assuming that the problem is with my images. Below is a snippet of the relevant error message.
PIL.UnidentifiedImageError: cannot identify image file ‘/var/www/data/ed92e8c4-9cd3-4a5a-9cf8-127bedc8b6fb/images/IMG_0008.tif’
app.execute()
File “/code/opendm/types.py”, line 342, in run
File “/code/stages/dataset.py”, line 109, in process
p = types.ODM_Photo(f)
File “/code/opendm/photo.py”, line 79, in init
self.parse_exif_values(path_file)
File “/code/opendm/photo.py”, line 255, in parse_exif_values
self.width, self.height = get_image_size.get_image_size(_path_file)
File “/code/opendm/get_image_size.py”, line 19, in get_image_size
width = img.shape[1]
AttributeError: ‘NoneType’ object has no attribute ‘shape’
