I think part of the problem could be the lack of side lap? ODM perhaps should try to do a better job of handling linear datasets like this one. Have you tried to process it with some other software?
Also try to isolate a single band and process it individually. Do you get a better reconstruction in that case for a single band?
Thank you for your input.
I think you might be right. I have lots of images but only processed a small sequence subset (that’s why they follow that path).
I will process the entire dataset and share the results.
There are 5 individual orthos. All aligned. No single multi-channel ortho.
There were no errors that seemed to be related to the linear nature of the data set.
