Message.....: An orthophoto could not be generated. To generate one, make sure GPS information is embedded in the EXIF tags of your images, or use a Ground Control Points (GCP) file
Folks, Progresss. Once I converted the data to jpg, The processing went further. I copied the Task output message at the bottom of this post. I believe the imagery does not contain the GPS information. I attached my error messages and examples of the data below. I appreciate your help.
Tom
Here is a screen shot of the messages:
Example files from original dataset
… output truncated at 500 lines …
Processing view “0085” (with colors)…
Processing view “0086” (with colors)…
Processing view “0087” (with colors)…
Processing view “0088” (with colors)…
Processing view “0089” (with colors)…
Processing view “0090” (with colors)…
Processing view “0091” (with colors)…
Processing view “0092” (with colors)…
Processing view “0093” (with colors)…
Processing view “0094” (with colors)…
Processing view “0095” (with colors)…
Processing view “0096” (with colors)…
Processing view “0097” (with colors)…
Processing view “0098” (with colors)…
Processing view “0099” (with colors)…
Processing view “0100” (with colors)…
Processing view “0101” (with colors)…
Processing view “0102” (with colors)…
Processing view “0103” (with colors)…
Processing view “0104” (with colors)…
Processing view “0105” (with colors)…
Processing view “0106” (with colors)…
Processing view “0107” (with colors)…
Processing view “0108” (with colors)…
Processing view “0109” (with colors)…
Processing view “0110” (with colors)…
Processing view “0111” (with colors)…
Processing view “0112” (with colors)…
Processing view “0113” (with colors)…
Processing view “0114” (with colors)…
Processing view “0115” (with colors)…
Processing view “0116” (with colors)…
Processing view “0117” (with colors)…
Processing view “0118” (with colors)…
Processing view “0119” (with colors)…
Processing view “0120” (with colors)…
Processing view “0121” (with colors)…
Processing view “0122” (with colors)…
Processing view “0123” (with colors)…
Processing view “0124” (with colors)…
Processing view “0125” (with colors)…
Processing view “0126” (with colors)…
Processing view “0127” (with colors)…
Processing view “0128” (with colors)…
Processing view “0129” (with colors)…
Processing view “0130” (with colors)…
Processing view “0131” (with colors)…
Processing view “0132” (with colors)…
Processing view “0133” (with colors)…
Processing view “0134” (with colors)…
Processing view “0135” (with colors)…
Processing view “0136” (with colors)…
Processing view “0137” (with colors)…
Processing view “0138” (with colors)…
Processing view “0139” (with colors)…
Processing view “0140” (with colors)…
Processing view “0141” (with colors)…
Processing view “0142” (with colors)…
Processing view “0143” (with colors)…
Processing view “0144” (with colors)…
Processing view “0145” (with colors)…
Processing view “0146” (with colors)…
Processing view “0147” (with colors)…
Processing view “0148” (with colors)…
Processing view “0149” (with colors)…
Processing view “0150” (with colors)…
Processing view “0151” (with colors)…
Processing view “0152” (with colors)…
Processing view “0153” (with colors)…
Processing view “0154” (with colors)…
Processing view “0155” (with colors)…
Processing view “0156” (with colors)…
Processing view “0157” (with colors)…
Processing view “0158” (with colors)…
Processing view “0159” (with colors)…
Processing view “0160” (with colors)…
Processing view “0161” (with colors)…
Processing view “0162” (with colors)…
Processing view “0163” (with colors)…
Processing view “0164” (with colors)…
Processing view “0165” (with colors)…
Processing view “0166” (with colors)…
Processing view “0167” (with colors)…
Processing view “0168” (with colors)…
Processing view “0169” (with colors)…
Processing view “0170” (with colors)…
Processing view “0171” (with colors)…
Processing view “0172” (with colors)…
Processing view “0173” (with colors)…
Processing view “0174” (with colors)…
Processing view “0175” (with colors)…
Processing view “0176” (with colors)…
Processing view “0177” (with colors)…
Processing view “0178” (with colors)…
Processing view “0179” (with colors)…
Processing view “0180” (with colors)…
Processing view “0181” (with colors)…
Processing view “0182” (with colors)…
Processing view “0183” (with colors)…
Processing view “0184” (with colors)…
Processing view “0185” (with colors)…
Processing view “0186” (with colors)…
Processing view “0187” (with colors)…
Processing view “0188” (with colors)…
Processing view “0189” (with colors)…
Processing view “0190” (with colors)…
Processing view “0191” (with colors)…
Processing view “0192” (with colors)…
Processing view “0193” (with colors)…
Processing view “0194” (with colors)…
Processing view “0195” (with colors)…
Processing view “0196” (with colors)…
Processing view “0197” (with colors)…
Processing view “0198” (with colors)…
Processing view “0199” (with colors)…
Processing view “0200” (with colors)…
Processing view “0201” (with colors)…
Processing view “0202” (with colors)…
Processing view “0203” (with colors)…
Processing view “0204” (with colors)…
Processing view “0205” (with colors)…
Processing view “0206” (with colors)…
Processing view “0207” (with colors)…
Processing view “0208” (with colors)…
Processing view “0209” (with colors)…
Processing view “0210” (with colors)…
Processing view “0211” (with colors)…
Processing view “0212” (with colors)…
Processing view “0213” (with colors)…
Processing view “0214” (with colors)…
Processing view “0215” (with colors)…
Processing view “0216” (with colors)…
Processing view “0217” (with colors)…
Processing view “0218” (with colors)…
Processing view “0219” (with colors)…
Processing view “0220” (with colors)…
Processing view “0221” (with colors)…
Processing view “0222” (with colors)…
Processing view “0223” (with colors)…
Processing view “0224” (with colors)…
Processing view “0225” (with colors)…
Processing view “0226” (with colors)…
Processing view “0227” (with colors)…
Processing view “0228” (with colors)…
Processing view “0229” (with colors)…
Processing view “0230” (with colors)…
Processing view “0231” (with colors)…
Processing view “0232” (with colors)…
Processing view “0233” (with colors)…
Processing view “0234” (with colors)…
Processing view “0235” (with colors)…
Processing view “0236” (with colors)…
Processing view “0237” (with colors)…
Processing view “0238” (with colors)…
Processing view “0239” (with colors)…
Processing view “0240” (with colors)…
Processing view “0241” (with colors)…
Processing view “0242” (with colors)…
Processing view “0243” (with colors)…
Processing view “0244” (with colors)…
Processing view “0245” (with colors)…
Processing view “0246” (with colors)…
Processing view “0247” (with colors)…
Processing view “0248” (with colors)…
Processing view “0249” (with colors)…
Processing view “0250” (with colors)…
Processing view “0251” (with colors)…
Processing view “0252” (with colors)…
Processing view “0253” (with colors)…
Processing view “0254” (with colors)…
Processing view “0255” (with colors)…
Processing view “0256” (with colors)…
Processing view “0257” (with colors)…
Processing view “0258” (with colors)…
Processing view “0259” (with colors)…
Processing view “0260” (with colors)…
Processing view “0261” (with colors)…
Processing view “0262” (with colors)…
Processing view “0263” (with colors)…
Processing view “0264” (with colors)…
Processing view “0265” (with colors)…
Processing view “0266” (with colors)…
Processing view “0267” (with colors)…
Processing view “0268” (with colors)…
Processing view “0269” (with colors)…
Processing view “0270” (with colors)…
Processing view “0271” (with colors)…
Processing view “0272” (with colors)…
Processing view “0273” (with colors)…
Processing view “0274” (with colors)…
Processing view “0275” (with colors)…
Processing view “0276” (with colors)…
Processing view “0277” (with colors)…
Processing view “0278” (with colors)…
Processing view “0279” (with colors)…
Writing final point set (75682547 points)…
Writing PLY file (75682547 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] running /code/SuperBuild/src/elibs/mve/apps/meshclean/meshclean -t0.6 --no-clean --component-size=0 “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/mve/mve_dense_point_cloud.ply” “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/mve/mve_dense_point_cloud.filtered.ply”
MVE FSSR Mesh Cleaning (built on Nov 19 2019, 17:33:00)
Loading mesh: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/mve/mve_dense_point_cloud.ply
PLY Loader: comment Export generated by libmve
Reading PLY: 75682547 verts…
done.
Removing low-confidence geometry (threshold 0.6)…
Deleted 23793729 low-confidence vertices.
Writing mesh: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/mve/mve_dense_point_cloud.filtered.ply
Writing PLY file (51888818 verts, with colors, with normals, with confidences, with values, 0 faces)…
done.
[INFO] Finished mve stage
[INFO] Filtering point cloud (statistical, meanK 16, standard deviation 2.5)
[INFO] running /code/build/bin/odm_filterpoints -inputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/mve/mve_dense_point_cloud.ply -outputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_filterpoints/point_cloud.ply -sd 2.5 -meank 16 -sample 0
[INFO] Writing ODM Mesh file in: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_mesh.ply
[INFO] running /code/SuperBuild/src/PoissonRecon/Bin/Linux/PoissonRecon --in /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_filterpoints/point_cloud.ply --out /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_mesh.dirty.ply --depth 9 --pointWeight 4 --samplesPerNode 1.0 --threads 4 --linearFit
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_mesh.dirty.ply -outputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_mesh.ply -removeIslands -decimateMesh 100000
[INFO] Writing ODM 2.5D Mesh file in: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_25dmesh.ply
[INFO] ODM 2.5D DSM resolution: 0.08
[INFO] Created temporary directory: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp
[INFO] running pdal info /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_filterpoints/point_cloud.ply > /tmp/tmphZZlxU.json
[INFO] Point cloud bounds are [minx: -4.457793236, maxx: 4.521449089] [miny: -7.533065796, maxy: 7.800810337]
[INFO] DEM resolution is (192, 113), max tile size is 4096, will split DEM generation into 1 tiles
[INFO] Generating /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/mesh_dsm_r0.11313708499_x0_y0.tif (max, radius: 0.11313708499, resolution: 0.08)
[INFO] running pdal pipeline -i /tmp/tmpSWHGCl.json > /dev/null 2>&1
[INFO] running gdalbuildvrt “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.vrt” “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/mesh_dsm_r0.11313708499_x0_y0.tif”
[INFO] running gdal_translate -co NUM_THREADS=5 --config GDAL_CACHEMAX 45.3% /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.vrt /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.tmp.tif
Input file size is 113, 192
0
[INFO] running gdal_translate -co NUM_THREADS=5 --config GDAL_CACHEMAX 45.3% -outsize 10% 0 /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.tmp.tif /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.small.tif
0
[INFO] running gdal_fillnodata.py -co NUM_THREADS=5 --config GDAL_CACHEMAX 45.3% -b 1 -of GTiff /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.small.tif /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.small_filled.tif
0
…10…20…
30…40…50
60
.70…80…90…
.100 - done.
[INFO] running gdalbuildvrt -resolution highest -r bilinear “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/merged.vrt” “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.small_filled.tif” “/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.tmp.tif”
0…10…20…30…40…50
[INFO] running gdal_translate -co NUM_THREADS=5 --config GDAL_CACHEMAX 45.3% /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/merged.vrt /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/tiles.tif
0
[INFO] Starting smoothing…
[INFO] Smoothing iteration 1
[INFO] Completed smoothing to create …/var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/mesh_dsm.tif in 0:00:00.122727
[INFO] Completed mesh_dsm.tif in 0:08:23.584925
[INFO] Creating mesh from DSM: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/mesh_dsm.tif
[INFO] running /code/SuperBuild/src/dem2mesh/dem2mesh -inputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/tmp/mesh_dsm.tif -outputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_25dmesh.dirty.ply -maxTileLength 4000 -maxVertexCount 100000
[INFO] running /code/build/bin/odm_cleanmesh -inputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_25dmesh.dirty.ply -outputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_25dmesh.ply -removeIslands -decimateMesh 100000
[INFO] Finished odm_meshing stage
[INFO] Running mvs_texturing stage
[INFO] Writing MVS Textured file in: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_texturing/odm_textured_model.obj
[INFO] running /code/SuperBuild/install/bin/texrecon /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/opensfm/reconstruction.nvm /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_mesh.ply /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_texturing/odm_textured_model -d gmi -o gauss_clamping -t none -n 65535
/code/SuperBuild/install/bin/texrecon (built on Nov 19 2019, 17:31:20)
Load and prepare mesh:
Reading PLY: 85753 verts…
171315 faces…
done.
Generating texture views:
NVM: Loading file…
NVM: Number of features: 218367
Loading 100%… done. (Took 14.994s)
Building adjacency graph:
Adding edges 100%… done. (Took 0.501s)
256878 total edges.
View selection:
Building BVH from 171315 faces…
done. (Took: 252 ms)
Calculating face qualities 100%… done. (Took 14.007s)
Postprocessing face infos 100%… done. (Took 0.077s)
Maximum quality of a face within an image: 1240.2
Clamping qualities to 67.4738 within normalization.
Writing data cost file…
done.
Optimizing:
Time[s] Energy
0 111376
0 110335
1 108471
1 107545
1 107136
1 106973
2 106841
2 106800
3 106741
3 106692
3 106666
3 106648
3 106630
4 106613
10453 faces have not been seen
Took: 19.416s
Generating texture patches:
Running…
done. (Took 4.475s)
210 texture patches.
Running global seam leveling:
done.
Lhs dimensionality: 87481 x 87481
Calculating adjustments:
Color channel 2: CG took 83 iterations. Residual is 9.31194e-05
Color channel 1: CG took 83 iterations. Residual is 9.31194e-05
Color channel 0: CG took 83 iterations. Residual is 9.31194e-05
Took 0.196 seconds
Adjusting texture patches 100%… done. (Took 0.948s)
Running local seam leveling:
Blending texture patches 100%… done. (Took 12.533s)
Generating texture atlases:
Sorting texture patches…
done.
Working on atlas 4 100%… done.
Finalizing texture atlases…
done. (Took: 3.868s)
Building objmodel:
Saving model…
done.
Whole texturing procedure took: 67.706s
[INFO] Writing MVS Textured file in: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_texturing_25d/odm_textured_model.obj
[INFO] running /code/SuperBuild/install/bin/texrecon /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/opensfm/reconstruction.nvm /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_meshing/odm_25dmesh.ply /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_texturing_25d/odm_textured_model -d gmi -o gauss_clamping -t none --nadir_mode -n 65535
Reading PLY: 21696 verts…
42784 faces…
done.
NVM: Loading file…
Loading 100%… done. (Took 15.306s)
Adding edges 100%… done. (Took 0.115s)
63873 total edges.
View selection:
Building BVH from 42784 faces…
done. (Took: 36 ms)
Calculating face qualities 100%… done. (Took 9.832s)
Postprocessing face infos 100%… done. (Took 0.009s)
Maximum quality of a face within an image: 20261.3
Clamping qualities to 405.267 within normalization.
done.
Optimizing:
Time[s] Energy
0 34154
0 33856
0 33527
0 33328
0 33238
0 33206
0 33184
0 33174
0 33159
1 33157
1 33152
1 33149
1 33146
1 33143
23058 faces have not been seen
Took: 11.189s
Running…
done. (Took 4.126s)
156 texture patches.
done.
Lhs dimensionality: 12326 x 12326
Color channel 1: CG took 107 iterations. Residual is 9.92762e-05
Color channel 0: CG took 107 iterations. Residual is 9.92762e-05
Color channel 2: CG took 107 iterations. Residual is 9.92762e-05
Took 0.043 seconds
Adjusting texture patches 100%… done. (Took 0.707s)
Blending texture patches 100%… done. (Took 10.916s)
done.
done. (Took: 3.659s)
Building objmodel:
Saving model…
done.
Whole texturing procedure took: 55.038s
[WARNING] NO SRS: The output point cloud will not have a SRS.
[WARNING] Georeferencing failed. Make sure your photos have geotags in the EXIF or you have provided a GCP file.
[INFO] Running odm_dem stage
[INFO] Classify: False
[INFO] Create DSM: True
[INFO] Create DTM: False
[INFO] DEM input file /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_georeferencing/odm_georeferenced_model.laz found: False
[INFO] Finished odm_dem stage
[INFO] running /code/build/bin/odm_orthophoto -inputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_texturing_25d/odm_textured_model.obj -logFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_orthophoto/odm_orthophoto_log.txt -outputFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_orthophoto/odm_orthophoto.png -resolution 50.0 -outputCornerFile /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f/odm_orthophoto/odm_orthophoto_corners.txt
[WARNING] No geo-referenced orthophoto created due to missing geo-referencing or corner coordinates.
[INFO] Finished odm_orthophoto stage
[INFO] No more stages to run
[INFO] MMMMMMMMMMMNNNMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMNNNMMMMMMMMMMM
[INFO] MMMMMMdo:…—…/sNMMMMMMMMMMMMMMMMMMMMMMMMMMNs/…—…:odMMMMMM
[INFO] MMMMy-.odNMMMMMNy//mMMMMMMMMMMMMMMMMMMMMMMm//hNMMMMMNdo.-yMMMM
[INFO] MMN/sMMMMMMMMMNNMm/yMMMMMMMMMMMMMMMMMMMMy/mMNNMMMMMMMMNs/MMM
[INFO] MM/ hMMMMMMMMNs.+MMM/ dMMMMMMMMMMMMMMMMMMh +MMM+.sNMMMMMMMMh +MM
[INFO] MN /MMMMMMNo/./mMMMMN :MMMMMMMMMMMMMMMMMM: NMMMMm/./oNMMMMMM: NM
[INFO] Mm +MMMMMN+ /MMMMMMM-MMMMMMMMMMMMMMMMMM-MMMMMMM: oNMMMMM+ mM
[INFO] MM…NMMNs./mNMMMMMMMy sMMMMMMMMMMMMMMMMMMo hMMMMMMMNm/.sNMMN-MM [INFO] MMd:mMNomMMMMMMMMMy:MMMMMMMNmmmmNMMMMMMN:hMMMMMMMMMdoNMm-dMM [INFO] MMMm:.omMMMMMMMMNh/ sdmmho/.-``-/sddh+ /hNMMMMMMMMdo.:mMMM [INFO] MMMMMd+--/osss+:-:/ :- .ym+ hmo``:-` `+:-:ossso/-:+dMMMMM [INFO] MMMMMMMNmhysosydmNMo /ds`/NMM+ hMMd..dh. sMNmdysosyhmNMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMMs .:-:``hmmN+ yNmds -:.:`-NMMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMN.-mNm- //:::. -:://: +mMd`-NMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM+ dMMN -MMNNN+ yNNNMN :MMMs sMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM`.mmmy /mmmmm/ smmmmm``mmmh :MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM``:::- ./////. -:::::` :::: -MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMM:`mNNd /NNNNN+ hNNNNN .NNNy +MMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMd`/MMM.`ys+//. -/+oso +MMN.`mMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMMMMMMMy /o:- `oyhd/ shys+ `-:s-`hMMMMMMMMMMMMMMMMMM [INFO] MMMMMMMMNmdhhhdmNMMM` +d+ sMMM+ hMMN:`hh- sMMNmdhhhdmNMMMMMMMM [INFO] MMMMMms:::/++//::+ho .+- /dM+ hNh- +/` -h+:://++/::/smMMMMM [INFO] MMMN+./hmMMMMMMNds- ./oso:.``:. :-``.:os+- -sdNMMMMMMmy:.oNMMM [INFO] MMm-.hMNhNMMMMMMMMNo`/MMMMMNdhyyyyhhdNMMMM+`oNMMMMMMMMNhNMh.-mMM [INFO] MM:`mMMN/-sNNMMMMMMMo yMMMMMMMMMMMMMMMMMMy sMMMMMMMNNs-/NMMm`:MM [INFO] Mm /MMMMMd/.-oMMMMMMN :MMMMMMMMMMMMMMMMMM-`MMMMMMMo-./dMMMMM/ NM [INFO] Mm /MMMMMMm:-`sNMMMMN :MMMMMMMMMMMMMMMMMM-`MMMMMNs`-/NMMMMMM/ NM [INFO] MM:`mMMMMMMMMd/-sMMMo yMMMMMMMMMMMMMMMMMMy sMMMs-/dMMMMMMMMd`:MM [INFO] MMm-.hMMMMMMMMMdhMNo`+MMMMMMMMMMMMMMMMMMMM+`oNMhdMMMMMMMMMh.-mMM [INFO] MMMNo./hmNMMMMMNms--yMMMMMMMMMMMMMMMMMMMMMMy--smNMMMMMNmy/.oNMMM [INFO] MMMMMms:-:/+++/:-+hMMMMMMMMMMMMMMMMMMMMMMMMMNh+-:/+++/:-:smMMMMM [INFO] MMMMMMMMNdhhyhdmMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMmdhyhhmNMMMMMMMM [INFO] MMMMMMMMMMMMMMMNNNNNMMMMMMNNNNNNMMMMMMMMNNMMMMMMMNNMMMMMMMMMMMMM [INFO] MMMMMMMMMMMMMh/-...-+dMMMm......:+hMMMMs../MMMMMo..sMMMMMMMMMMMM [INFO] MMMMMMMMMMMM/ /yhy- sMMm -hhy/ :NMM+ oMMMy /MMMMMMMMMMMM [INFO] MMMMMMMMMMMy /MMMMN` NMm /MMMMo +MM: .` yMd :MMMMMMMMMMMM
[INFO] MMMMMMMMMMM+ sMMMMM: hMm /MMMMd -MM- /s h.d- -MMMMMMMMMMMM
[INFO] MMMMMMMMMMMs +MMMMM. mMm /MMMMy /MM. +M/ yM: MMMMMMMMMMMM [INFO] MMMMMMMMMMMN- smNm/ +MMm :NNdo .mMMoMM+/yMM/ MMMMMMMMMMMM [INFO] MMMMMMMMMMMMNo- :yMMMm :sNMMM sMMMMMMM+ NMMMMMMMMMMM
[INFO] MMMMMMMMMMMMMMMNmmNMMMMMMMNmmmmNMMMMMMMNNMMMMMMMMMNNMMMMMMMMMMMM
[INFO] OpenDroneMap app finished - Mon Nov 25 09:23:00 2019
Postprocessing: /var/www/data/ff9a73f2-aeb7-4816-a1c7-7754f154714f
No orthophoto found at odm_orthophoto/odm_orthophoto.tif: will skip tiling
Found point cloud: odm_filterpoints/point_cloud.ply
Converting odm_filterpoints/point_cloud.ply to odm_georeferencing/odm_georeferenced_model.laz, even though it’s not georeferenced…
Metadata:
Bounds: [(-5, -8, -4), (5, 8, 0)]
Cube: [(-9, -9, -11), (9, 9, 7)]
Storing dimensions: [
X:int32, Y:int32, Z:int32, Intensity:uint16, ReturnNumber:uint8,
NumberOfReturns:uint8, ScanDirectionFlag:uint8,
EdgeOfFlightLine:uint8, Classification:uint8, ScanAngleRank:float,
UserData:uint8, PointSourceId:uint16, GpsTime:double, Red:uint16,
Green:uint16, Blue:uint16, OriginId:uint32
Build parameters:
Span: 256
Resolution 2D: 256 * 256 = 65,536
Resolution 3D: 256 * 256 * 256 = 16,777,216
Maximum node size: 65,536
Minimum node size: 16,384
Cache size: 64
Adding 0 - odm_georeferencing/odm_georeferenced_model.laz
Pushes complete - joining...
/var/www/scripts/postprocess.sh: line 117: 18916 Killed entwine build --threads $(nproc) --tmp “entwine_pointcloud-tmp” -i “$pointcloud_input_path” -o entwine_pointcloud
Compressing all.zip
Done!
Here is a screen shot of my settings:
After My job finished, the CPU resources were not returned to my computer.
but after I closed the webodm manager, cpu resources were returned but memory resources were not.
I’m going to reboot and this time try a fast orthophoto.
