I have three datasets from flights flown over different sections of a river reach, with overlap. Each flight has its own set of radiometric calibration images associated with it. Each flight has about 2700 images in it. If I combine all the datasets, then the software has three sets of calibration data, without any indication of which photos they belong to. If I process the three datasets separately, I’m not sure how to merge them into one large image.
Do you have software from the vendor of your mulispectral camera to do the radiometric calibration with?
If you pre-process each of the three sets so the radiometric calibration is “burned-in” for the images, then you should just be able to pass them all as one Task to get processed together no issue.
