I’m having trouble densifying my point cloud, generated from around 550 photos with no GCP files. I think I’m out of memory on the docker container:
…VmPeak: 2358236 kB
…VmSize: 2268088 kB
I’m struggling to see how to increase memory for the containers. I’ve attempted to use the following command: docker update -m 100g opendronemap/odm:gpu but no docker image can be found. I think this is because I only run the container each time the command is called.
As you can see my kernel does not support the memory limit argument for docker:
–memory=“100g”
I’ve that my system grub config needs to be altered to enable this however I’d prefer not to do this as I’m working on a remote machine via ssh and it’s a pain to access it physically should something go wrong.
So my questions are:
- Am I right in thinking it’s a memory issue?
- If so, how would I go about fixing it?
docker run --memory=“100g” -ti --rm -v /media/mal/working_files/odm_data:/odm_data --gpus all opendronemap/odm:gpu --project-path /odm_data $ODMPROJ --dsm --skip-3dmodel --feature-quality high --mesh-octree-depth 12 --min-num-features 10000 --pc-quality medium;
WARNING: Your kernel does not support swap limit capabilities or the cgroup is not mounted. Memory limited without swap.
[INFO] Initializing ODM - Mon Aug 09 13:43:47 2021
[INFO] ==============
[INFO] build_overviews: False
[INFO] camera_lens: auto
[INFO] cameras: {}
[INFO] crop: 3
[INFO] debug: False
[INFO] dem_decimation: 1
[INFO] dem_gapfill_steps: 3
[INFO] dem_resolution: 5
[INFO] dsm: True
[INFO] dtm: False
[INFO] end_with: odm_report
[INFO] fast_orthophoto: False
[INFO] feature_quality: high
[INFO] feature_type: sift
[INFO] force_gps: False
[INFO] gcp: None
[INFO] geo: None
[INFO] gps_accuracy: 10
[INFO] ignore_gsd: False
[INFO] matcher_distance: 0
[INFO] matcher_neighbors: 8
[INFO] matcher_type: flann
[INFO] max_concurrency: 8
[INFO] merge: all
[INFO] mesh_octree_depth: 12
[INFO] mesh_size: 200000
[INFO] name: Pen-y-banc
[INFO] orthophoto_kmz: False
[INFO] orthophoto_png: False
[INFO] pc_classify: False
[INFO] pc_csv: False
[INFO] pc_ept: False
[INFO] pc_filter: 2.5
[INFO] pc_las: False
[INFO] pc_quality: medium
[INFO] pc_rectify: False
[INFO] pc_sample: 0
[INFO] pc_tile: False
[INFO] primary_band: auto
[INFO] project_path: /odm_data
[INFO] rerun: None
[INFO] rerun_all: False
[INFO] rerun_from: None
[INFO] resize_to: 2048
[INFO] skip_3dmodel: True
[INFO] skip_report: False
[INFO] sm_cluster: None
[INFO] smrf_scalar: 1.25
[INFO] smrf_slope: 0.15
[INFO] smrf_threshold: 0.5
[INFO] smrf_window: 18.0
[INFO] split: 999999
[INFO] split_overlap: 150
[INFO] tiles: False
[INFO] time: False
[INFO] use_3dmesh: False
[INFO] use_exif: False
[INFO] verbose: False
[INFO] Running dataset stage
[INFO] Loading dataset from: /odm_data/Pen-y-banc/images
[INFO] Loading images database: /odm_data/Pen-y-banc/images.json
[INFO] Found 594 usable images
[INFO] Coordinates file already exist: /odm_data/Pen-y-banc/odm_georeferencing/coords.txt
[INFO] Model geo file already exist: /odm_data/Pen-y-banc/odm_georeferencing/odm_georeferencing_model_geo.txt
[INFO] Parsing SRS header: WGS84 UTM 30N
[INFO] Finished dataset stage
[INFO] Running split stage
[INFO] Finished split stage
[INFO] Running merge stage
[INFO] Finished merge stage
[INFO] Running opensfm stage
[WARNING] /odm_data/Pen-y-banc/opensfm/image_list.txt already exists, not rerunning OpenSfM setup
[WARNING] Detect features already done: /odm_data/Pen-y-banc/opensfm/features exists
[WARNING] Match features already done: /odm_data/Pen-y-banc/opensfm/matches exists
[WARNING] Found a valid OpenSfM tracks file in: /odm_data/Pen-y-banc/opensfm/tracks.csv
[WARNING] Found a valid OpenSfM reconstruction file in: /odm_data/Pen-y-banc/opensfm/reconstruction.json
[INFO] Already extracted cameras
[WARNING] Found existing reconstruction stats /odm_data/Pen-y-banc/opensfm/stats/stats.json
[WARNING] Will skip exporting /odm_data/Pen-y-banc/opensfm/reconstruction.geocoords.json
[INFO] Undistorting /odm_data/Pen-y-banc/opensfm …
[WARNING] Already undistorted (nominal)
[WARNING] Found a valid OpenSfM NVM reconstruction file in: /odm_data/Pen-y-banc/opensfm/undistorted/reconstruction.nvm
[INFO] Finished opensfm stage
[INFO] Running openmvs stage
[WARNING] Found existing /odm_data/Pen-y-banc/opensfm/undistorted/openmvs/scene.mvs
[INFO] Estimating depthmaps
[INFO] running /code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud “/odm_data/Pen-y-banc/opensfm/undistorted/openmvs/scene.mvs” --resolution-level 2 --min-resolution 684 --max-resolution 2093 --max-threads 8 --number-views-fuse 2 -w “/odm_data/Pen-y-banc/opensfm/undistorted/openmvs/depthmaps” -v 0
13:43:52 [App ] Build date: May 25 2021, 16:11:57
13:43:52 [App ] CPU: Intel(R) Core™ i7-7700K CPU @ 4.20GHz (8 cores)
13:43:52 [App ] RAM: 62.70GB Physical Memory 2.00GB Virtual Memory
13:43:52 [App ] OS: Linux 5.4.0-80-generic (x86_64)
13:43:52 [App ] SSE & AVX compatible CPU & OS detected
13:43:52 [App ] Command line: /odm_data/Pen-y-banc/opensfm/undistorted/openmvs/scene.mvs --resolution-level 2 --min-resolution 684 --max-resolution 2093 --max-threads 8 --number-views-fuse 2 -w /odm_data/Pen-y-banc/opensfm/undistorted/openmvs/depthmaps -v 0
13:43:58 [App ] Preparing images for dense reconstruction completed: 594 images (4s969ms)
13:44:21 [App ] Selecting images for dense reconstruction completed: 0 images (23s771ms)
Fused depth-maps 0 (100%, 0ms)
13:44:21 [App ] Densifying point-cloud completed: 0 points (28s809ms)
13:44:21 [App ] MEMORYINFO: {
13:44:21 [App ] VmPeak: 2358236 kB
13:44:21 [App ] VmSize: 2268088 kB
13:44:21 [App ] } ENDINFO
[INFO] running /code/SuperBuild/install/bin/OpenMVS/DensifyPointCloud --filter-point-cloud -1 -i “/odm_data/Pen-y-banc/opensfm/undistorted/openmvs/scene_dense.mvs” -v 0
13:44:21 [App ] Build date: May 25 2021, 16:11:57
13:44:21 [App ] CPU: Intel(R) Core™ i7-7700K CPU @ 4.20GHz (8 cores)
13:44:21 [App ] RAM: 62.70GB Physical Memory 2.00GB Virtual Memory
13:44:21 [App ] OS: Linux 5.4.0-80-generic (x86_64)
13:44:21 [App ] SSE & AVX compatible CPU & OS detected
13:44:21 [App ] Command line: --filter-point-cloud -1 -i /odm_data/Pen-y-banc/opensfm/undistorted/openmvs/scene_dense.mvs -v 0
13:44:21 [App ] error: empty initial point-cloud
Child returned 1
File “/code/opendm/types.py”, line 338, in run
File “/code/opendm/types.py”, line 319, in run
File “/code/stages/openmvs.py”, line 160, in process
system.run(‘%s %s’ % (context.omvs_densify_path, ’ '.join(config)))
File “/code/opendm/system.py”, line 90, in run
[ERROR] Uh oh! Processing stopped because of strange values in the reconstruction. This is often a sign that the input data has some issues or the software cannot deal with it. Have you followed best practices for data acquisition? See https://docs.opendronemap.org/flying.html
Link to my images:
https://liveuclac-my.sharepoint.com/:f:/g/personal/tcrnbgh_ucl_ac_uk/Ev8YOo3rubtHs4VPQHdxXIEBsfJY-bVdFYBMXOEbyw0yEQ?e=b7TMHk
