I’m new to using ODM and docker. I’ve read a lot of articles about ODM and how it can process Drone imagery but I’m wondering if ODM is possible in processing satellite imagery that are 10gb per image?
I have a couple satellite images that I want to try to process and play with using ODM and it doesn’t seem to be working. I highly likely be doing something wrong in between that’s making the process fail as well since I’m not quite sure if I have the setting correct and such. But just want to know if ODM is capable of taking images that are so large.
There was a little typo, it’s actually around 700mb per images but you are correct, the images I have is from a push broom camera, so maybe that’s why it’s not working. Thanks for helping out!
